SSH from Windows PC into PinePhone?
#21
I saw that my top thread in the Pine64 forum was about «Bluetooth low energy & ANT+ sports sensors Pinephone distro?»:
https://forum.pine64.org/showthread.php?tid=10172
It had 28,700 views, but I suppose 28,700 viewers where disappointed, since altough I am highly interested in this topic, i did not get it to work since several years.
The Rasperri ANT+ which reads out sensor data from a Rasperri PI with ANT+ stick was developed on June 19, 2014 by Johannes Bader, a former PhD student from ETH Swiss Federal Institute of Technology in Zurich. It seems that a PhD in computer science is requred to read out sensor data from a Garmin watch in real-time.
Is also a PhD in computer science required to connect from a Windows PC to a PinePhone?
We made another trial following the instruction of wibble. We use PostmarketOS posh.
sudo apk add wayvnc
wayvnc -r 0.0.0.0 to listen on all the phone s IP adresses
On Tiger VNC viewer on the Windows PC, whe entered in the VNC server field of VNC viewer:
192.168.1.103:5900
where 192.168.1.103 is the ip adress of the phone and 5900 is the port wibble suggested
Whe get a Tiger VNC error message:
connection to 192.168.1.103:5900 failed.
Unable to connect socket. A connection trial failed, since the partner did not react, time out, the connection was faulty or the host did not react (10060).
We had an error message with TigerVNC. It was a  Connection refused/timed out error and is already known:
https://wiki.postmarketos.org/wiki/VNC#Troubleshooting
we had to enter:
apk add postmarketos-config-nftables-vncserver
service nftables restart
Then, it was possible to connect with  TigerVNC on a Windows PC to a Pinephone. What we can say after a first test:
- The Pinephone screen is mirrored fine
- The Windows mouse always worked fine, and showed up on the HDMI screen and on the Pinephone
- The Windows keyboard sometimes worked, sometimes did not work
- A test with the Gnome editor worked fine to write some text
with LibreOffice:
- Sometimes it was possible to drop down the menus with the PC mouse, sometimes not
- Sometimes the PC keyboard worked, sometimes not
- The PinePhone keyboard sometimes worked with LibreOffice, sometimes not
- When we installed LibreOffice on the PinePhone, it was possible to connect a Cap Clip Bluetooth mouse, write a file, drop down the menu and save the file.
- When connected to a Windows PC, whe had to restart the phone several times, sometimes, the menu worked, sometimes the keyboard worked.
- To save a file via keyboard and mouse on the HDMI monitor worked, but it was tricky.
  Pinephone visibly losing power while plugged in Hiraghm 10 9,593 10-14-2026, 04:20 PM
Last Post: Flymoon
  Pinephone software Csanderson0313 3 1,950 07-10-2026, 02:21 PM
  PinePhone Game Thread PixelPaintbrush 31 88,176 06-11-2026, 02:50 PM
Last Post: elinkser
  How can I record video on a Pinephone? kk22 23 26,629 03-25-2026, 12:55 PM
Last Post: baptx
  pinephone-support package not upgradable on Mobian fhireman 5 8,932 02-28-2026, 05:49 PM
Last Post: baptx
  beep - playing PCM samples on PinePhone? WhiteHexagon 0 1,759 12-04-2025, 08:07 AM
Last Post: WhiteHexagon
Star Selling my Pinephone Pro Explorer Edition zheyon 2 5,354 12-01-2025, 10:25 AM
  PinePhone sensors - Gyroscope power WhiteHexagon 3 3,024 11-30-2025, 08:07 AM
  Light Sensor / Proximity Sensor on PinePhone? WhiteHexagon 1 2,389 11-18-2025, 03:07 PM
  Pinephone boot. Richy_T 8 8,810 10-21-2025, 12:12 PM
Last Post: Richy_T
