Keyboard case not charging (or not working) and a possible FIX for both
I had the same issue, keyboard working but no charge unless I pressed the shell and phone.
Since I thought I saw a slight bulge I got suspicious of the plastic "guide" pin in the shell. It would make sense since it seems the pogos closest to it has the problems.
So I took a knife and remove a few millimeters of the plastic guide pin and now my keyboard shell seems to work as it should.
I have no idea what longterm ill effects this might have but for now it works for me.
(04-25-2022, 04:04 AM)Humid Stylus Wrote: Since I thought I saw a slight bulge I got suspicious of the plastic "guide" pin in the shell. It would make sense since it seems the pogos closest to it has the problems.
Thanks for this suggestion.
I started having the same problem with the keyboard not connecting to the PinePhone today. I came to the same conclusion after having no success with contact cleaner and reinstalling the PinePhone a couple of times. If I pressed on the back of the case directly above the pogo pins it would connect, but only while I kept pressing. I was looking at the keyboard case where the pogo pins connect and also noticed the rectangular locating pin. After reading your comment I used a sharp craft knife and shaved a fraction of a mm off the pin. It now connects easily with both keyboard and power.
If it's like the ordinary PinePhone back cover that's a retaining clip not a guide pin, and you sometimes have to press the back cover there for it to engage. The only reason to have a clip in the middle like that is to improve contact on the pogo pins, but if the clip isn't engaged it will make contact worse.
  Rii mini 4 keyboard and touchpad work over Bluetooth Peter Gamma 2 5,444 06-04-2026, 12:16 PM
Last Post: elinkser
  Pinephone (Pro) Keyboard Case for sale manubert 8 19,209 05-15-2026, 11:36 AM
Last Post: oliveira11670
  NEW pinephone keyboard case and LoRa backplate for sale ragele 0 2,972 01-12-2026, 06:09 PM
Last Post: ragele
  keyboard case charging but not typing new2pinephone 19 26,985 02-14-2025, 04:09 PM
Last Post: zltpxqhp69o2
  Searching for a PinePhone Keyboard Case RubiksCube 1 5,422 10-07-2024, 11:08 PM
  Troubleshooting Pinedio LoRa Add-on Case nickp 2 4,461 09-29-2024, 09:17 PM
Last Post: lavabrilliant
  Getting started with fingerprint scanner case lolgzs 1 5,558 09-08-2024, 04:21 AM
Last Post: mfashby
  So which keyboard you suggest for the Pinephone? Peter Gamma 21 23,180 07-19-2024, 08:05 AM
Last Post: Peter Gamma
  Bring the Pinephone keyboard back, it is worth it! Peter Gamma 1 5,261 07-04-2024, 07:32 AM
Heart The Pinephone keyboard offers alternative layouts Peter Gamma 0 3,137 07-04-2024, 05:40 AM
