Mobian + tow boot + emmc flash = boot loop
I recently installed tow-boot to get wake-from-suspend working, and I saw that it was supposed to make flashing to emmc possible as well.
I followed the instructions on the wiki, flashing once from an SD card boot of mobian, and another time from my desktop by booting the pinephone pro as a usb mass storage device. Both times when I try to reboot I get a red light, and then an amber light, repeat.
I used dd every time. I flashed the *.img file from the latest Mobian weekly build.
Before flashing I saw some people claim that mobian will work on emmc after installing tow-boot, but is it possible that it still doesn't for some devices? Is it maybe the version of mobian that I'm using? Something else maybe?
Thanks for reading.
I was able to install to eMMC by using the Mobian installer (April 3rd build) loaded onto an SD card.
(04-07-2022, 11:47 AM)spropine Wrote: I was able to install to eMMC by using the Mobian installer (April 3rd build) loaded onto an SD card.
I noticed that none of the April weekly build images are working for me on SD or EMMC.
I will try the installer.  Thanks for the info!
I'm still unable to get Mobian on eMMC to work, despite verifying that the filesystem from the image was dd'd correctly onto the eMMC via tow-boot's jumpdrive feature. As the OP said, I get the blue light, then the yellow light, but then the yellow light persists and it never boots. This is different behavior from when the eMMC is blank or corrupted, in which case the LED blinks red at me. @spropine @sringgen did you ever get this to work? Thanks
I downloaded a May image of Mobian for PPP if I remember the date right, and later copied it with dd onto a 64G SD, extended the partition with the disk tool, put the chip into the PPP, and then booted the PPP (with tow-boot) while pressing the down volume button.
Previously, I had a copy working on the internal storage by using the same method.
The apt-get update; apt-get dist-upgrade command will get you a working system as of today, Saturday December 31.
Rainbow Let's get the PPP and Mobian working! Rsquared 0 487 06-15-2026, 12:01 AM
Last Post: Rsquared
Exclamation Pinephone Pro wont boot to anything! Supervisor 5 3,935 08-18-2025, 06:15 PM
  No rk2aw boot menu jebez 7 4,525 07-09-2025, 07:12 AM
Last Post: mikehenson
  Backing up data on Pinephone Pro to hard disk, optical disk and flash? Www 4 3,603 06-29-2025, 02:46 PM
Last Post: Dendrocalamus64
  debian mobian not bootable after 2025-04-05 upgrade henrythemouse 3 4,305 04-26-2025, 11:56 PM
Last Post: henrythemouse
Information Fix PinePhone Pro when unable to boot due to drained battery butjar 8 16,289 03-13-2025, 08:40 PM
Last Post: pcb
  PinePhone doesn't boot anymore lapin 3 3,556 09-13-2024, 10:09 AM
Last Post: lapin
  How to boot from SD card in PPP joespodie 2 4,541 08-02-2024, 02:49 PM
Question The Case of the Vanishing EMMC DieSkaarj 9 9,943 07-28-2024, 04:19 PM
Last Post: dchang0
  Can't boot Pinephone Pro into Factory Test Build for Hardware Checking jydoxcen 3 4,325 02-17-2024, 04:04 AM
Last Post: fxc
