soundcard pinephone mobian
hi, I'm new here and more and more happy with my pinephone, just awaitng the keyboard next days.
I'm using the phone as my daily driver and even the camera is somehow charming.......having its own character.....
I' m a DJ( ....exp. rock, noiserock......) and have the pinephone used for DJing, which is running quite o.k., due to Lollypop and the docking- board.
Now I'm wondering if it is possible to connect an external soundcard to the pinephone?
Which one you would recommend.......a real good one?
Thank you!
It's confirmed working with the RME Babyface.
https://forum.pine64.org/showthread.php?tid=13884
It should work with pretty much any audio interface that works with linux, and since you're using the powered dock the power requirements shouldn't be a problem. That covers most USB DACs. If you're after interfaces with inputs or multiple channels you'll need to do a bit more compatibility research. What are your requirements?
(02-04-2022, 09:20 AM)wibble Wrote: It's confirmed working with the RME Babyface.
thank you, the link is interesting, but a babyface is real expensive.................my requirements are always the same: a great sound quality! And for an easyier DJing interfaces with inputs/ multiple channels would be great..............any recommendations?
You did ask for a real good one, and didn't specify price ;-) I don't know enough about DJing to know what features you need, what might be useful but isn't really necessary, and what's no use at all. Mic inputs? Balanced or single ended inputs and outputs? Physical knobs rather than virtual controls? Headphone outputs?
https://linuxmusicians.com/ should give you an idea about whether most interfaces work, or if people have compatibility problems. https://audiosciencereview.com has measurements for some of them so you can see how good the inputs and outputs are - it doesn't say much else about features or linux compatibility unless someone comments on them. The MOTU M2 and M4 apparently work well with kernel 5.11 or later. Gen1 and Gen2 Focusrite Scarletts should work well, and low channel count Gen3 might be ok. At the really cheap end I'd expect the Fun Generation UA-202 to work since the Behringer UCA202 does, and they use the same chipset.
(02-06-2022, 12:20 PM)wibble Wrote: You did ask for a real good one, and didn't specify price ;-) I don't know enough about DJing to know what features you need, what might be useful but isn't really necessary, and what's no use at all. Mic inputs? Balanced or single ended inputs and outputs? Physical knobs rather than virtual controls? Headphone outputs?
Hey, thanx a lot for a lot of great links........I think I' ll go for the MOTU M2........and tell my experience...........
  Mobian MMS/SMS text problem bcnaz 16 38,987 06-23-2026, 06:53 AM
Last Post: mehdy
  Mobian image for the PinePhone Korfou 2 1,697 04-27-2026, 09:57 AM
Last Post: Korfou
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 80 67,994 12-24-2025, 12:11 AM
  cryptocurrency on mobian/pinephone biketool 33 73,269 10-08-2025, 06:21 AM
  XLibre for Mobian Hiraghm 0 3,347 06-29-2025, 12:38 PM
Last Post: Hiraghm
  Axolotl on PinePhone / Mobian arno_nuehm 223 343,668 06-25-2025, 01:19 PM
Last Post: anonymous
  VoIP account on mobian dialer j_s 0 3,021 06-15-2025, 04:19 PM
Last Post: j_s
  Mobian Pinephone Notification LED biketool 2 4,184 06-07-2025, 03:19 PM
  Vivaldi Web browser nearly native for Mobian biketool 3 4,925 05-06-2025, 02:19 AM
  mobian calamares fail merom 2 4,632 04-29-2025, 02:10 PM
Last Post: mdk
