Pinephone Pro impossible to switch on
hello everybody,
i received my PinePhone pro a few day ago. I was very happy. Everything worked fine until impossible to switch on.
Impossible to connect from my laptop (not present with lsusb), no message on phone's screen (nothing). I try to boot on SD card, no way....
Could you please help me?
Regards,
Hi @gerard
Have you got your phone started yet ?
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
(01-29-2022, 07:13 AM)gerard Wrote: hello everybody,
Regards,
I also can't connect to a laptop.  Still using the Manjaro install that comes with the phone.  I can see the device with lsusb after connecting the USB A/C while pressing the RE button on the back, but I can never get the connected message/image on the phone or in any way access the eMMC or microSD (other than from the phone itself).  I've connected the USB A/C while PPP is powered off, powered on, pressing RE, using a USB2 port, a USB3 port, with the microSD inserted / not inserted, on a train, on a plane, while wearing sox, and with a fox.
I also flashed postmarketOS to the microSD and inserted it.  I've tried every way I can find described to boot from the microSD including these instructions from the wiki, https://wiki.pine64.org/wiki/PinePhone_Pro:
The Explorer Edition comes with a modified U-Boot pointing to the microSD card pre-installed to the eMMC. The microSD card can be (temporarily) booted instead of the pre-installed operating system, when the power key is shortly held at boot. To always boot from the microSD card it is recommended to wipe U-Boot from the eMMC. When the pre-installed bootloader was overwritten with a bootloader without such a configuration, the RE button underneath the back cover of the phone can also be used to temporarily bypass the eMMC. The button may however only be pressed shortly for a few seconds during boot, otherwise the eMMC won't be initialized in the operating system.
Lastly, I read somewhere about booting while pressing power/volume up simultaneously.  That doesn't work either.
Any thoughts?
  Pinephone visibly losing power while plugged in Hiraghm 10 9,670 10-14-2026, 04:20 PM
Last Post: Flymoon
  Pinephone software Csanderson0313 3 1,973 07-10-2026, 02:21 PM
  PinePhone Game Thread PixelPaintbrush 31 88,283 06-11-2026, 02:50 PM
Last Post: elinkser
  How can I record video on a Pinephone? kk22 23 26,716 03-25-2026, 12:55 PM
Last Post: baptx
  pinephone-support package not upgradable on Mobian fhireman 5 8,955 02-28-2026, 05:49 PM
Last Post: baptx
  beep - playing PCM samples on PinePhone? WhiteHexagon 0 1,769 12-04-2025, 08:07 AM
Last Post: WhiteHexagon
Star Selling my Pinephone Pro Explorer Edition zheyon 2 5,371 12-01-2025, 10:25 AM
  PinePhone sensors - Gyroscope power WhiteHexagon 3 3,050 11-30-2025, 08:07 AM
  Light Sensor / Proximity Sensor on PinePhone? WhiteHexagon 1 2,405 11-18-2025, 03:07 PM
  Pinephone boot. Richy_T 8 8,834 10-21-2025, 12:12 PM
Last Post: Richy_T
