Error running docker on Pinephone with Manjaro (cgroup)
I am running into an error when launching docker on Manjaro. I read on some other forums that it might be an issue with cgroup v2. Not sure how to fix this on the Pinephone.
Error message:
INFO[2022-01-06T10:06:59.267970912-08:00] shim disconnected                             id=6c95e631b40d83a9868b724490b14eedb608c646f1edbb292fe2806f0af75597
WARN[2022-01-06T10:06:59.268656611-08:00] cleaning up after shim disconnected           id=6c95e631b40d83a9868b724490b14eedb608c646f1edbb292fe2806f0af75597 namespace=moby
INFO[2022-01-06T10:06:59.268802359-08:00] cleaning up dead shim
WARN[2022-01-06T10:06:59.370041508-08:00] cleanup warnings time="2022-01-06T10:06:59-08:00" level=info msg="starting signal loop" namespace=moby pid=4966
ERRO[2022-01-06T10:06:59.373118051-08:00] copy shim log                                 error="read /proc/self/fd/13: file already closed"
ERRO[2022-01-06T10:06:59.376856045-08:00] stream copy error: reading from a closed fifo
ERRO[2022-01-06T10:06:59.377685784-08:00] stream copy error: reading from a closed fifo
WARN[2022-01-06T10:06:59.421226054-08:00] Failed to delete conntrack state for 172.17.0.2: invalid argument
ERRO[2022-01-06T10:06:59.537262095-08:00] 6c95e631b40d83a9868b724490b14eedb608c646f1edbb292fe2806f0af75597 cleanup: failed to delete container from containerd: no such container
ERRO[2022-01-06T10:06:59.537450884-08:00] Handler for POST /v1.41/containers/6c95e631b40d83a9868b724490b14eedb608c646f1edbb292fe2806f0af75597/start returned error: failed to create shim: OCI runtime create failed: container_linux.go:380: starting container process caused: process_linux.go:545: container init caused: process_linux.go:508: setting cgroup config for procHooks process caused: bpf_prog_query(BPF_CGROUP_DEVICE) failed: function not implemented: unknown
How to reproduce:
dockerd &
docker run alpine
Output of /proc/version
Linux version 5.15.11-1-MANJARO-ARM (builduser@fh-mjr-build-lon-xlarge) (gcc (GCC) 10.2.0, GNU ld (GNU Binutils) 2.35) #1 SMP PREEMPT Wed Dec 22 17:45:45 UTC 2021
Thank you for your help.
  New PinePhone user issues greenpineuser 8 8,098 12-19-2024, 09:47 PM
Last Post: emilianojay
  PinePhone Beta Edition will not boot from MicroSD card Timothy_Ecc 10 19,306 10-04-2024, 12:01 AM
Last Post: spazz
  Pinephone with KDE plasma - Battery drain when phone is not used Daniello 1 3,885 07-03-2024, 08:38 PM
  link for supported pinephone os manjharo et all penguins_rule 3 4,638 05-09-2024, 03:02 AM
Last Post: Eugo
  systemic issue pinephone penguins_rule 3 4,910 04-02-2024, 11:52 AM
  Manjaro: Settings doesnt open nbh 0 3,235 09-24-2023, 05:25 PM
Last Post: nbh
  Can't get ring on Manjaro Pine Phone thorensjubilee 12 16,538 06-09-2023, 04:40 AM
Last Post: thorensjubilee
  Is Manjaro ARM a Rolling Release? jojuma 4 6,897 05-10-2023, 09:27 PM
  new PinePhone upgrade issue WhiteHexagon 5 7,672 05-09-2023, 04:09 PM
Last Post: WhiteHexagon
  Where Does Manjaro Phosh Store Its Custom Keystrokes? jakfish 0 3,609 04-25-2023, 09:49 AM
Last Post: jakfish
