PinePhone Beta 3GB modem not working
the modem shows up in the gui (Arch Linux arm and Plasma Mobile with gdm intstead of lightdm) and with "mmcli -m any" but it shows always "failed" and "sim-missing"
please help
(12-29-2021, 08:30 AM)hannescam Wrote: the modem shows up in the gui (Arch Linux arm and Plasma Mobile with gdm intstead of lightdm) and with "mmcli -m any" but it shows always "failed" and "sim-missing"
please help
let's take simple advices first. shutdown the machine and after that remove battery. reason for this is because modem chip takes power from battery.
try different installation on sdcard, my suggestion would be phosh. plasma tend to be rather unreliable.
it shows only "No SIM" and a sim logo with a questionmark
Is it possible that SIM pins were damaged by an adapter? Several people have reported that kind of problem on the forum. Another possibility would be the SIM card not making good contact. I had that problem intermittently and solved it by installing a thin plastic shim cut from a milk bottle between the SIM and metal cage of the socket (barely visible in photo).
[Image: AmvV4M7r_o.jpg]
i used instead of the plastic sheet two layers of tabe but with no sucess
Are you in the correct slot ? (Lower one)
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
yes i use the lower slot for the sim and the upper for a 64gb microsdcard
Did this sim card work in another phone ? Have you already activated the card ?
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
this sim works fully in a nokia lumia 610 windows phone
that brings us back to the phone.
Can you see or inspect inside the sim socket if you remove the sim card ?
If the contacts look undamaged, then maybe a thicker plastic shim like Zeb recommended ?
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
  Pinephone software Csanderson0313 1 112 1 hour ago
Last Post: zetabeta
  PinePhone Game Thread PixelPaintbrush 31 81,517 06-11-2026, 02:50 PM
Last Post: elinkser
  How can I record video on a Pinephone? kk22 23 22,972 03-25-2026, 12:55 PM
Last Post: baptx
  Pinephone visibly losing power while plugged in Hiraghm 8 7,304 03-09-2026, 07:51 PM
Last Post: Tia Vaughan
  pinephone-support package not upgradable on Mobian fhireman 5 7,403 02-28-2026, 05:49 PM
Last Post: baptx
  beep - playing PCM samples on PinePhone? WhiteHexagon 0 1,113 12-04-2025, 08:07 AM
Last Post: WhiteHexagon
Star Selling my Pinephone Pro Explorer Edition zheyon 2 4,418 12-01-2025, 10:25 AM
  PinePhone sensors - Gyroscope power WhiteHexagon 3 1,953 11-30-2025, 08:07 AM
  Light Sensor / Proximity Sensor on PinePhone? WhiteHexagon 1 1,532 11-18-2025, 03:07 PM
  Pinephone boot. Richy_T 8 7,140 10-21-2025, 12:12 PM
Last Post: Richy_T
