Comparing the Librem 5 USA and PinePhone Beta
I wrote up some observations about the differences between the L5USA and PP:
[Image: l5-vs-pp-side-view.jpg?fit=440%2C330]
I would like to hear any feedback/critiques and know whether other people are seeing the same performance differences between the two phones.
I’ll probably post more observations later about the PP on my blog, now that I have it in my grubby little hands and can try using it as a phone. Sadly, I had to send the L5USA back to Purism for servicing and I don’t know when I’ll get back to the US to pick it up.
It's super long, so it might probably take me many weeks to get through it I think.
But I went through a little bit, and one thing caught my eyes:
[Image: l5vspp_thermals.jpg?w=1024]
I noticed an "X" button on the Librem screen, but not on the Pine screen.
Was this button present on the Librem 5 from the very beginning, or did you enable it by yourself?
In the case of the latter, which Gsetting is that?
母語は日本語ですが、英語も喋れます(ry
@amosbatto  thank you for the detailed comparison. It is super interesting. That must have been a lot of work!
The more I read about the Librem5, the more I like it. I don't mind the price; however I cannot justify to myself spending more than the combined cost of my last four cars, let alone to my wife!
Thank you for he write up.
:wq
(12-10-2021, 07:06 PM)ryo Wrote: I noticed an "X" button on the Librem screen, but not on the Pine screen.
In "dconf editor", go to "org / gnome / desktop / wm / preferences / button-layout" -> use default value ("appmenue:close")
On my PineTab it will be set back when docked -> undocked
(12-10-2021, 07:06 PM)ryo Wrote: In the case of the latter, which Gsetting is that?
This should do it:
gsettings set org.gnome.desktop.wm.preferences button-layout ":close"
Going back to normal is a
gsettings set org.gnome.desktop.wm.preferences button-layout ""
away.
This should do it:
away.
Thanks, this worked.
I toyed around with it by adding the other 2 buttons, but seems like those did nothing, so I removed maximize and minimize again, but I'll keep the close button.
  Pinephone visibly losing power while plugged in Hiraghm 9 8,794 08-29-2026, 11:18 AM
Last Post: baptx
  Pinephone software Csanderson0313 3 1,584 07-10-2026, 02:21 PM
  PinePhone Game Thread PixelPaintbrush 31 86,250 06-11-2026, 02:50 PM
Last Post: elinkser
  How can I record video on a Pinephone? kk22 23 25,622 03-25-2026, 12:55 PM
Last Post: baptx
  pinephone-support package not upgradable on Mobian fhireman 5 8,519 02-28-2026, 05:49 PM
Last Post: baptx
  beep - playing PCM samples on PinePhone? WhiteHexagon 0 1,601 12-04-2025, 08:07 AM
Last Post: WhiteHexagon
Star Selling my Pinephone Pro Explorer Edition zheyon 2 5,107 12-01-2025, 10:25 AM
  PinePhone sensors - Gyroscope power WhiteHexagon 3 2,759 11-30-2025, 08:07 AM
  Light Sensor / Proximity Sensor on PinePhone? WhiteHexagon 1 2,167 11-18-2025, 03:07 PM
  Pinephone boot. Richy_T 8 8,378 10-21-2025, 12:12 PM
Last Post: Richy_T
