Comparing the Librem 5 USA and PinePhone Beta
I wrote up some observations about the differences between the L5USA and PP:
[Image: l5-vs-pp-side-view.jpg?fit=440%2C330]
I would like to hear any feedback/critiques and know whether other people are seeing the same performance differences between the two phones.
I’ll probably post more observations later about the PP on my blog, now that I have it in my grubby little hands and can try using it as a phone. Sadly, I had to send the L5USA back to Purism for servicing and I don’t know when I’ll get back to the US to pick it up.
It's super long, so it might probably take me many weeks to get through it I think.
But I went through a little bit, and one thing caught my eyes:
[Image: l5vspp_thermals.jpg?w=1024]
I noticed an "X" button on the Librem screen, but not on the Pine screen.
Was this button present on the Librem 5 from the very beginning, or did you enable it by yourself?
In the case of the latter, which Gsetting is that?
母語は日本語ですが、英語も喋れます(ry
@amosbatto  thank you for the detailed comparison. It is super interesting. That must have been a lot of work!
The more I read about the Librem5, the more I like it. I don't mind the price; however I cannot justify to myself spending more than the combined cost of my last four cars, let alone to my wife!
Thank you for he write up.
:wq
(12-10-2021, 07:06 PM)ryo Wrote: I noticed an "X" button on the Librem screen, but not on the Pine screen.
In "dconf editor", go to "org / gnome / desktop / wm / preferences / button-layout" -> use default value ("appmenue:close")
On my PineTab it will be set back when docked -> undocked
(12-10-2021, 07:06 PM)ryo Wrote: In the case of the latter, which Gsetting is that?
This should do it:
gsettings set org.gnome.desktop.wm.preferences button-layout ":close"
Going back to normal is a
gsettings set org.gnome.desktop.wm.preferences button-layout ""
away.
This should do it:
away.
Thanks, this worked.
I toyed around with it by adding the other 2 buttons, but seems like those did nothing, so I removed maximize and minimize again, but I'll keep the close button.
  Why projects like PinePhone matter – feedback and encouragement Gary2003 13 12,256 09-16-2025, 01:13 PM
Last Post: Gary2003
  Can use PlayStation on Pinephone? willharper 7 8,197 09-13-2025, 12:30 AM
Last Post: ChaiLetters
  Pinephone Pro Neural Processing Unit biketool 1 4,163 09-01-2025, 02:05 AM
  Want to buy second hand PinePhone 3G version rudi.timmermans 2 3,656 08-31-2025, 07:18 AM
Last Post: Fish
  beta release of a Linux mobile app strength training app coryholl 1 1,799 08-29-2025, 06:06 PM
Last Post: coryholl
  Pinephone Pro not in store? bubulux20c 1 2,024 08-08-2025, 02:12 AM
Last Post: P. Siera
  PinePhone Pro EU no warranty P. Siera 0 1,660 07-21-2025, 12:08 AM
Last Post: P. Siera
  US Mobile, via T-Mobile, won't support Pinephone Pro - SOLVED, SIMPLY jovval 14 15,388 07-18-2025, 04:24 PM
Last Post: dchang0
  Pinephone visibly losing power while plugged in Hiraghm 2 2,740 05-23-2025, 12:30 PM
  contact sales pinephone janjansen1312 2 3,034 03-17-2025, 07:29 PM
