u-boot flashing problem
I just flashed the eMMC with the u-boot.itb idbloader.img from Debian testing.
I might have mistaken to copy over the dd commands to flash the eMMC.
When I pressed the power-on button I get immediately on the serial port the u-boot output:
U-Boot TPL 2021.10+dfsg-1 (Oct 10 2021 - 04:20:52)
Channel 0: LPDDR4, 50MHz
BW=32 Col=10 Bk=8 CS0 Row=15 CS1 Row=15 CS=2 Die BW=16 Size=2048MB
Channel 1: LPDDR4, 50MHz
BW=32 Col=10 Bk=8 CS0 Row=15 CS1 Row=15 S=2 Die BW=16 Size=2048MB
256B stride
lpddr4_set_rate: change freq to 400000000 mhz 0, 1
lpddr4_set_rate: change freq to 800000000 mhz 1, 0
Trying to boot from BOOTROM
Returning to boot ROM...
U-Boot SPL 2021.10+dfsg-1 (Oct 10 2021 - 04:20:52 +0000)
Trying to boot from SPI
Trying to boot from MMC2
Card did not respond to voltage select! : -110
spl: mmc init failed with error: -95
SPL: failed to boot from all boot devices
### ERROR ### Please RESET the board ###
Event when I plug-in the SD Card, the output is identical. Any idea how to solve this?
BRgds
Cédric
Disable/remove emmc,, since bootrom searches SPI, emmc, sd (in that order)
for idbloader and later rest of uboot package
There is no 'magic' keystoke to skip emmc
Thanx, that worked.
  Boot Order in Pinebook Pro food 12 19,114 05-25-2026, 08:28 AM
Last Post: finmark
  Pinebook pro won't boot after bootloader installation jwensouls 4 8,651 08-21-2024, 04:17 AM
  Manjaro network problem late 2023 acruhl 1 4,062 01-19-2024, 11:32 PM
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 11,591 12-11-2023, 03:47 AM
Last Post: calinb
  [Manjaro] u-boot won't boot from eMMC with (unbootable) SD card present zackw 1 6,443 08-21-2023, 09:08 PM
Last Post: vanessadonald
  Help please, problem with xen domU guest on rockpro64 pine64 v2.1 mrc1965 1 3,289 08-21-2023, 09:05 PM
  Emergency Mode Boot Hotkey? jiacovelli 20 20,265 06-02-2023, 01:32 PM
  upgrade problem trying4firstbass 1 2,836 11-28-2022, 01:44 AM
  Tow Boot install help Paulie420 7 11,407 11-24-2022, 10:24 AM
Last Post: myself600
  Resume from suspend not working after flashing Tow-Boot to SPI xp19375 3 6,070 10-31-2022, 10:14 AM
