Protonmail in Geary
I am running Mobian Phosh.
I have protonmail-bridge installed following instructions I found in a post here but I cannot get protonmail set up in Geary.
I have tried to manually configure imap and smtp in geary and also in settings online accounts new imap and smtp but keep getting errors.
Is there a tutorial for this?
Will protonmail work in Geary?
When I try to configure IMAP in settings new online accounts
IMAP Server 127.0.0.1
username "myusername"
Password "my password"
I get error "Connection refused"
In the proton-bridge when I use the "info 0" command it returns my account information and a long password that is not the password I use to login with, I assume that is the password the bridge is using to decrypt messages. I have used that password as well as the password I login in with to no avail. Why is my connection refused?
(11-13-2021, 01:29 PM)tombull Wrote: I am running Mobian Phosh.
Hi tombull, this is how I got protonmail working with Geary.
I followed how to install bridge following the tutorial there:
https://www.reddit.com/r/PinePhoneOffici...pinephone/
After I get log in the Protonmail Bridge:
mobian@mobian:~/Downloads/proton-bridge$ ./proton-bridge --cli
            Welcome to ProtonMail Bridge interactive shell
                              ___....___
    ^^                __..-:'':__:..:__:'':-..__
                  _.-:__:.-:'':  :  :  :'':-.:__:-._
                .':.-:  :  :  :  :  :  :  :  :  :._:'.
            _ :.':  :  :  :  :  :  :  :  :  :  :  :'.: _
  :::::::::[ ]:__:__:__:__:__:__:__:__:__:__:__:__:__:[ ]:::::::::::
      jgs  [ ]                                        [ ]
    ~~^_~^~/  \~^-~^~ _~^-~_^~-^~_^~~-^~_~^~-~_~-^~_^/  \~^ ~~_ ^
>>> login yourlogin
Username: yourprotonmail@protonmail.com
Password: your protonmail password
Authenticating ...
Adding account ...
Account youraccount was added successfully.
>>> list
# : account              (status        , address mode  )
0 : youraccount        (connected      , combined      )
>>> info
Configuration for yourprotonmail@protonmail.com
IMAP Settings
Address:  127.0.0.1
IMAP port: 1143
Password:  ***very important password will be useful later***
Security:  STARTTLS
SMTP Settings
Address:  127.0.0.1
SMTP port: 1025
Security:  STARTTLS
Here is how my server settings are in Geary:
Service provider:  0.0.1
Save draft email on server, check
Save sent email on server, check
IMAP server 127.0.0.1:1143
Connection security StartTLS
Login name yourprotonmail@protonmail.com
SMTP server 127.0.0.1:1025
Login Use same login as receiving
***When setting up IMAP and SMTP, I used the password found by typing >>>info in the Protonmail-bridge command line***
EDIT: changed "Connection security" for Geary from "none" to "StartTLS" for IMAP and SMTP
It has been a little while since I've set that up so I might have forgotten some steps or details but that worth a try.
Hope that can help.
  When are we getting Geary back? LibrePhoneUser 15 17,476 12-09-2022, 04:18 AM
Last Post: Anna
  geary shulamy 2 4,360 09-10-2022, 03:01 AM
Last Post: shulamy
  Geary: can't write mail jsch 2 4,139 03-12-2022, 03:28 AM
Last Post: jsch
  Protonmail in geary r7s3TgmyQv2R3z 1 5,186 03-18-2021, 02:32 PM
Last Post: user12345
  Geary crashes during start after recent update p1trson 2 6,718 01-16-2021, 04:49 AM
Last Post: p1trson
  What am I doing wrong with Geary ? wi_badger 3 10,609 09-16-2020, 06:34 AM
Last Post: m.alizade7
  getting Geary working well on mobile is definitely in the works chris_02 3 8,042 07-07-2020, 05:41 AM
Last Post: pawlinski
  Disabling Geary notifications? johns 0 4,179 05-07-2020, 07:41 AM
Last Post: johns
