Setting up Mullvad to run on Mobian
I have tried setting up Mullvad to run through OpenVPN (exactly how the site tells you to set up the VPN through OpenVPN in a terminal on Debian), and while nothing obviously goes wrong and my openvpn files seem to be in the right place, when I try to run sudo service openvpn start, nothing happens. Similarly nothing happens with the other command on Mullvad's website. I can't seem to import any sort of .ovpn or .conf file to the built in networking manager (it throws an unknown error), and any info I can find online about this is irrelevant, dead or unhelpful. Any help would be appreciated.
Use wireguard instead, it's better. sudo apt-get install wireguard-tools, unpack the mullvad-generated wireguard .zip file in /etc/wireguard, sudo ls /etc/wireguard | shuf -n1 to pick a random node, wg-quick up mullvad-<...>.conf
(11-06-2021, 05:12 PM)Dendrocalamus64 Wrote: Use wireguard instead, it's better.  sudo apt-get install wireguard-tools, unpack the mullvad-generated wireguard .zip file in /etc/wireguard, sudo ls /etc/wireguard | shuf -n1 to pick a random node, wg-quick up mullvad-<...>.conf
Just adding I had to install resolvconf as it was not available on fresh Mobian install. Also wg-quick command required only the connection name without .conf
  Mobian MMS/SMS text problem bcnaz 16 39,291 06-23-2026, 06:53 AM
Last Post: mehdy
  Mobian image for the PinePhone Korfou 2 1,774 04-27-2026, 09:57 AM
Last Post: Korfou
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 80 68,818 12-24-2025, 12:11 AM
  cryptocurrency on mobian/pinephone biketool 33 73,621 10-08-2025, 06:21 AM
  XLibre for Mobian Hiraghm 0 3,403 06-29-2025, 12:38 PM
Last Post: Hiraghm
  Axolotl on PinePhone / Mobian arno_nuehm 223 346,478 06-25-2025, 01:19 PM
Last Post: anonymous
  VoIP account on mobian dialer j_s 0 3,075 06-15-2025, 04:19 PM
Last Post: j_s
  Mobian Pinephone Notification LED biketool 2 4,252 06-07-2025, 03:19 PM
  Vivaldi Web browser nearly native for Mobian biketool 3 5,007 05-06-2025, 02:19 AM
  mobian calamares fail merom 2 4,703 04-29-2025, 02:10 PM
Last Post: mdk
