double tap to wake support
I did some research about non-working double tap to wake feature (when in deep sleep), despite the touch hw has it (thanks anyone who helped BTW).
The problem is Goodix touch driver in mainline kernel doesn't seem to support Gesture (Doze?) mode:
https://github.com/torvalds/linux/blob/m...n/goodix.c
I found another driver which claims the support (it also follows from it's code):
https://github.com/goodix/goodix_gt9xx_public
Anyone willing to try the alternative driver? Does it fit at all?
@megous
PS:
GOODiX GT911 Programming Guide attached (might be relevant despite we have Goodix GT917S).
Please let me know if it's better to remove the document itself from here.
.pdf   GT911 Programming Guide_v0.1.pdf (Size: 466.26 KB / Downloads: 760)
I'm rather surprised there's somebody out there who supports wake to tap.
Plasma Mobile has this rather super annoying bug (because if it's forced on to you, it shouldn't be considered a feature for Kami sake), and still no option to turn it off.
母語は日本語ですが、英語も喋れます(ry
If I understood Ondřej's blog post correctly, this might currently not be possible to do:
2021–10–18: Pinephone Pro – support merged into my kernel tree Wrote:
  • And that was another issue. Power consumption should not vary when I touch the screen in suspended mode, but I've already debugged this issue in the past on the original Pinephone, and I was able to just enable the solution I've implemented to this problem previously. This solution is to power down the touchscreen in system suspend completely. With that the suspend power consumptions stays at 400mW no matter what I do
If "power down the touchscreen" means what it sounds like it does then I doubt it would be possible to still use gestures to send any signals to wake up the device from suspend.
(11-04-2021, 02:41 AM)ryo Wrote: Plasma Mobile has this rather super annoying bug (because if it's forced on to you, it shouldn't be considered a feature for Kami sake), and still no option to turn it off.
Isn't it the option?
https://invent.kde.org/plasma/kwin/-/merge_requests/778
(11-04-2021, 02:48 AM)marcih Wrote: This solution is to power down the touchscreen in system suspend completely.
I think this solution was chosen just because of the reason above - mainline driver doesn't support Doze mode.
With proper driver support, Gesture mode operating current is less that 1mA which is negligible:
GT917S-Datasheet
(11-04-2021, 05:08 AM)bam Wrote: Isn't it the option?
Next question, where can this option be set?
Based on the lack of responses when I asked, I'd assume there is no option.
@ryo, according to the patch itself, it's DoubleTapWakeup entry of Wayland group.
Try set it to "false" in ~/.config/kwinrc by analogy with other options (not sure if it's the right file, though) - it might not be accessible via UI yet.
  Wake up Call walter1950 6 1,332 11-06-2025, 06:18 AM
  Does PinePhone support long-term battery health optimization? roseblack 5 1,855 10-06-2025, 09:05 PM
  US Mobile, via T-Mobile, won't support Pinephone Pro - SOLVED, SIMPLY jovval 14 19,785 07-18-2025, 04:24 PM
Last Post: dchang0
  Wake-up call walter1950 9 4,048 06-18-2025, 08:38 PM
  Looking to pay for support. profileyourcity 1 2,071 09-18-2023, 12:25 PM
Last Post: zetabeta
  My customer support experience ionmich 1 2,220 08-15-2023, 03:17 PM
Last Post: fxc
Lightbulb Suggestion: NFC-F / FeliCa Support for next gen PinePhone or board add-on iamauser 0 1,930 03-11-2023, 10:21 AM
Last Post: iamauser
Sad PinePhone carrier support bucnham 2 3,024 12-27-2022, 12:37 AM
Last Post: rocket2nfinity
  pinephone-support package not upgradable on Mobian fhireman 4 5,780 09-24-2022, 08:01 AM
Last Post: dante404
  Carriers do not support PinePhone? rey70 22 25,517 02-07-2022, 09:06 PM
Last Post: bcnaz
