Reading SMS from the terminal?
It's annoying to have to find my phone just so I can get the code so I can login to a given site. I've got SSH enabled, is there a way for me to view texts or at least notifications from there?
I am pretty sure somebody posted the location of the text files that chatty displays (cannot find it right now). Something like a .var/chatty/... directory?
You should be able to find out which files the chatty process loads, e.g. using 'ps'.
Hope this helps
  lacriz
(10-16-2021, 08:12 AM)lacriz Wrote: I am pretty sure somebody posted the location of the text files that chatty displays (cannot find it right now). Something like a .var/chatty/... directory?
Hope this helps
  lacriz
Looking at lsof it looks like the file I'm looking for is /home/mobian/.purple/chatty/db/chatty-history.db so I guess I need to figure out some way to read an sqlite db from the terminal
Edit: came up with this and threw it into my .zshrc, works great
alias txts="sqlite3 ~/.purple/chatty/db/chatty-history.db -box \"select datetime(messages.time, 'unixepoch') AS time, threads.alias AS contact, replace(messages.body, char(10), ' ¶ ') AS message from messages join threads on messages.thread_id=threads.id order by time desc;\" | less -S"
you already got key issue but "wayvnc" could be useful as well. "xtigervncviewer" could be viewer program.
https://danct12.github.io/VNC-on-PinePhone/
https://www.kirsle.net/vnc-server-for-pinephone
The README for Chatty specifically says how you can use Chatty over SSH. I personally haven't tried it but please do and let me know how it goes!
https://source.puri.sm/Librem5/chatty
(10-18-2021, 12:41 PM)ragreenburg Wrote: The README for Chatty specifically says how you can use Chatty over SSH. I personally haven't tried it but please do and let me know how it goes!
That's pretty cool. It works aside from the fact I can't drag the window around unless I right click the handle and select 'move'
Nice, better than nothing! My work network blocks SSHing so I haven't tried using it yet. Glad to know it works though!
  after dist-upgrade, terminal is broken nelstomlinson 9 12,180 09-09-2021, 06:47 AM
Last Post: nelstomlinson
  How do you copy and paste into mobian terminal? Do you ssh instead? temp0rary 6 11,580 06-01-2021, 12:16 PM
Last Post: temp0rary
  Anyone know how to start a terminal at current dir with Nemo? rp3 6 10,427 01-19-2021, 10:04 AM
  Make 'terminal' on-screen keyboard the default 3x5co 0 3,277 12-27-2020, 05:11 PM
Last Post: 3x5co
  Terminal help noob444 4 7,462 10-25-2020, 03:56 AM
Last Post: wibble
