Sizing apps to fit to screen
Is there a recommended way of sizing apps to fit the screen? I saw this:
x=${xdotool search – onlyvisible – name Name-of-App) && xdotool windowsize $x 725 270 && xdotool window move $x 0 50
at:
https://wiki.mobian-project.org/doku.php...&s[]=click
Has anyone used it? I've have to reinstall Mobian a few times with my experimentation with other things and just wanted to be sure.
Thanks.
The easiest way is to just use scale-to-fit ("scale-to-fit $app true").
Thanks, I'll try that.
I recently upgraded to "Bookworm" and there were improvements to the "Display" selections in "Settings". Previously there was a 100% and a 200% setting. Now, there is 100%, 125%, 150%, 175% and 200%. 150% solved my problem for now. Thanks again and thanks to the programmer that improved the "Settings".
"Sometimes" just rocking between landscape and portrait the app will correct itself into correctly fitting the screen.
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
  New Install, apps start but don't show up on screen?! RT3 2 81 07-18-2025, 07:56 PM
  On-Screen Keyboard Arrow Keys biketool 10 2,280 03-27-2025, 03:03 PM
  mobian phosh on screen keyboard not popping up for Chromium/Electron apps grump_fiddle_reinstall 1 890 01-15-2025, 08:08 PM
  Proximity sensor is oversensitive (was "Screen blanks when making call") treebeard 6 6,086 08-05-2024, 06:12 AM
Last Post: baptx
  Keyboard not popping up on QT apps 3x5co 1 1,700 02-08-2024, 11:45 PM
  Screen auto-rotation sensitivity mdk 0 1,298 12-26-2023, 06:08 AM
Last Post: mdk
  Screen stay black unless power key pressed short freelectro 0 1,292 06-24-2023, 01:55 PM
Last Post: freelectro
  Unsuspend → Black screen mdk 15 11,257 06-22-2023, 11:20 AM
Last Post: Melechtna
  Lock screen question: always squeekboard tuxcall 1 2,146 02-02-2023, 08:51 PM
Last Post: Haibara23
  [solved] Black screen at boot time mdk 0 1,677 01-13-2023, 03:33 AM
Last Post: mdk
