How to use microSD card to extend storage on arch linux Phosh
Recently installed arch linux phosh on my pinephone, but the storage apparently ran out before I could even download anything to the phone, or do any other storage-related tasks.
What I'm trying to do is use my 128GB microSD card that I have just dd'd with /dev/zero as a method to extend the storage of my pinephone, thus letting me use it regularly. How can I accomplish this?
(09-22-2021, 12:50 PM)pineuser0 Wrote: Recently installed arch linux phosh on my pinephone, but the storage apparently ran out before I could even download anything to the phone, or do any other storage-related tasks.
Something is wrong, unless you are trying to run on a 4Gb SD-card? Arch will resize the root partition during first boot (and you will see the text messages on the screen) - my full arch installation with several added applications takes only 5.4Gb of disk. So I suspect the best thing to do would be to reinstall arch.
I assume you are using a Danct12 image?
(09-22-2021, 12:50 PM)pineuser0 Wrote: ...
There are many ways to utilise the SD-card for additional storage: all the standard Linux options apply, but instructions for example to use it for the /home directory are here.
A reinstallation fixed the problem, the image used both before and after was: https://github.com/dreemurrs-embedded/Pi...908.img.xz
  PinePhone AND/OR PinePhone Pro Arch Complete Install and Setup mikehenson 3 10,380 01-09-2025, 05:02 AM
  LibreOffice usable with Arch Linux on the Pinephone? Peter Gamma 2 4,321 07-28-2024, 05:12 AM
Last Post: Peter Gamma
  stuck between phosh and plasma aular 0 2,593 02-27-2024, 05:55 PM
Last Post: aular
  Updating Arch Linux _radv_ 8 9,737 02-20-2024, 09:35 AM
Last Post: _radv_
  How to install arch with FDE user641 3 6,102 01-11-2024, 10:18 PM
  How to find software app, on Arch Phosh? general_lee 5 9,346 10-15-2023, 10:12 PM
  Automount SD card or USB Stick magdesign 1 4,789 10-06-2023, 10:05 AM
Last Post: luppivega
  Arch auto mount usb example Lazy_one 2 9,569 10-06-2023, 09:36 AM
  Arch with FDE user641 1 4,080 07-29-2023, 08:27 AM
Last Post: alpineduck
  No keyboard on Arch Plasma when entering password on document Chief 0 3,416 12-03-2022, 08:35 PM
Last Post: Chief
