Screen-off = dead phone
I have been trying different distros on my Pinephone, and I love the layout and speed of Ubuntu Touch. However, whenever I turn the screen off, it will not wake up again (the screen flickers and then goes permanently black), and I have to hold the power-button for 10 seconds and boot it back up again. I haven't had any such problem on the other distros, so it clearly seems software-related.
This problem occurred on the latest 5/6 stable version downloaded from here: https://ci.ubports.com/job/rootfs/job/ro...stemimage/
Is this a known issue? Is there a workaround?
Thanks!
(05-09-2021, 01:55 PM)okgo Wrote: I have been trying different distros on my Pinephone, and I love the layout and speed of Ubuntu Touch. However, whenever I turn the screen off, it will not wake up again (the screen flickers and then goes permanently black), and I have to hold the power-button for 10 seconds and boot it back up again. I haven't had any such problem on the other distros, so it clearly seems software-related.
Thanks!
@okgo  Have you tried a 2 or 3 second press of the power button? I recall experiencing the screen flash like that some time back, and holding the power button for a few seconds worked for me. I'm currently running my PinePhone with UBPorts on the KernelUpgrade channel, and I'm not seeing that quick flash and back to black.
Mark
Thanks!
Mark
I tried various power-on methods... and since it flickered the screen and then went black again, it makes me think that something was attempted and then failed - rather than that I wasn't hitting the button right. But I'm all ears for solutions!
I'd suggest trying the kernel update channel. At this point it works better for me than stable. If you don't like it you can always change back.
I've had the same problem with Ubuntu Touch, but I haven't tried the "kernel update channel". I'll look for it.
Is this what you meant? https://ci.ubports.com/job/rootfs/job/ro...elupgrade/
I've confirmed that the problem with the blank screen does not occur with the kernel upgrade image.
Yes, I also confirm that downloading from here worked without the dead-screen problem https://ci.ubports.com/job/rootfs/job/ro...elupgrade/
But unfortunately UbuntuTouch just doesn't seem to be there yet. Camera doesn't work, Firefox, Yubikey, and a real Bitwarden client missing...
(05-30-2021, 05:57 PM)okgo Wrote: Yes, I also confirm that downloading from here worked without the dead-screen problem https://ci.ubports.com/job/rootfs/job/ro...elupgrade/
I am having the exact same problem right now.  I will try this image. If I can't get this to work I will try Postmarket OS.  Love Ubuntu touch when it is running though
Just pulled the latest image from here : https://ci.ubports.com/job/rootfs/job/ro...stemimage/
and installed it to a new pine phone right out of the box to internal flash and i'm running into the exact same problem.
Cannot wake the device by pressing the button on the side singularly or holding it for 2-3 seconds. Once the screen fades out, you cant wake the device. Totally unusable.
Is there a fix for this? The link shown above appears to be broken and reference to that build looks like it wont build anymore?!
Any help is appreciated, this is my first experience with the pinephone out of the box
(09-15-2021, 10:47 AM)jtn0514 Wrote: Just pulled the latest image from here : https://ci.ubports.com/job/rootfs/job/ro...stemimage/
Switch update settings to release candidate channel, and update. Just be careful and not let the phone sleep while you do it... Tongue
  E-mail on the pine phone thorensjubilee 4 8,453 02-05-2023, 04:57 AM
Last Post: thorensjubilee
  How to answer a call on a sleeping phone Athansor 1 6,370 10-20-2021, 05:03 PM
Last Post: lacriz
  PinePhone UBPorts Edition stuck on PINE64 logo screen Giovanni Iannotti 4 12,163 09-01-2021, 01:20 PM
Last Post: Giovanni Iannotti
Sad Help! - Screen blank after update. Zweitaktmotor 4 10,861 07-26-2021, 05:17 PM
Last Post: Zweitaktmotor
  Making phone calls PinePhoneCoder 7 18,103 03-23-2021, 06:33 AM
Last Post: israel
  noticable Screen flicker KNERD 0 3,625 01-13-2021, 09:00 PM
Last Post: KNERD
  Copy To SD Card, All I get Is Red Light & Black Screen . . . . NobodyNew1 9 19,975 09-13-2020, 08:59 PM
Last Post: NobodyNew1
  Is UT in PinePhone same thing than in another phone? natasha 23 43,749 08-24-2020, 10:23 AM
Last Post: Cree
  Mint Mobile & Pine Phone Lt. Dillinger 10 27,540 08-14-2020, 04:00 PM
Last Post: klick
  Unable to make a phone call bingo600 4 11,400 07-23-2020, 10:18 AM
Last Post: israel
