(ARCHIVED) Ubuntu Xenial Image (BSP Kernel)
(06-17-2016, 09:06 PM)texadactyl Wrote:
(06-17-2016, 08:19 PM)Rickyroller5 Wrote:
(02-28-2016, 03:07 PM)longsleep Wrote: I also built a mimimal Ubuntu image combined with the the BSP Kernel and my image building gear. Similar to the Arch Image **this image is intended for developers. If you are looking for accelerated 2D/3D or video decoding use Android** and do not bother with trying this image.
Let me know what you think.
Longsleep,
  Noob nere. I keep seeing "image." Ubuntu image, download image, etc, etc image.
I thought images were pictures.
What exactly does it mean to say; "Ubuntu image"?
Thank you.
Rickyroller5
He means a disk volume image.  A disk volume image generally takes the form of a file which is input to the Unix/Linux `dd` utility in creating the actual disk volume.
Ah, so the "disk volume image" creates the place on your SD card for the distro to run?
Longsleep,
Thank you.
Rickyroller5
Roughly, yes.  The disk volume image is a file which is isomorphic to an entire disk of any type: HDD, SSD, USB, MicroSD, etc.  This file is often compressed in some form so to conserve storage and minimize download time.
Let me give you an example to help clarify. Basically an image is a reflection of everything on a storage device. For example, I could take an image of my windows hard drive and the result would be a single file that contains everything in my hard drive. (Windows operating system, personal files, images, MP3's, etc/...) I could send you that image and then you could copy it to a hard drive and when you boot it, your computer would look just like mine. In practice, it is very easy to both create images and install images.
In the world of Windows, the easiest tool is called Win32diskimager and it allows you to both take an image and write an image.
In the world of Pine (and pretty much all similar systems) someone creates an image of a known good state and version of Linux. The users then decompress and copy that image to an SD Card and the result is fully bootable Linux OS. In our case, most of the images are maintained by third parties like Longsleep and Lenny.
(06-22-2016, 05:51 AM)jl_678 Wrote: Hi,
OK, Got it. It seems though that this terminology "could" create some confusion if, say one person is thinking image, as in; jpeg, bitmap, etc. and another person is thinking image, as in; disk image.
 I guess you would consider the context of the conversation. :-D
Thanks for clarifying this for me. I appreciate it.
I am wishing for just a pure basic version of Ubuntu 16.04 server. Command Line Interface only, no desktop no bells and whistles, just a pure server version of Xenial. I have the Ubuntu Mate and I hate it... in fact I can't stand it, it's boring. Anyway, attempting to flash your build but wondering what core root_fs you used or if you can show us how to create an img file of 16.04 server that would be great.
(03-11-2016, 02:42 PM)mane Wrote: I've tested the ethernet capabilities and find out that download speed is ok (~820Mb/s) but upload speed stops at ~140Mb/s. I don't know if that's an hardware issue or just a something related to software/driver.
Is someone able to test their PINE64 in order to see if the behaviour is different please?
ISP limits upload speeds. You get about 20% of upload speed at best.
Desktop GUI's are overrated... give me a pure CLI any day. If I can get the server version loaded, I'll install Node.js and use that to serve up various web apps.
Flashed and up and running CLI only. Just what I wanted. Thanks Longsleep.
All my builds can be reproduced and the building gear is available on GitHub. See https://github.com/longsleep/build-pine6...tfs.sh#L61 for the details what rootfs is used for Xenial.
just jumping in here; can I ask why we're on kernel 3.10? Is it not possible to get current kernels to run on the Pine64?
Thanks!
(07-09-2016, 02:39 PM)yodermk Wrote: just jumping in here; can I ask why we're on kernel 3.10?  Is it not possible to get current kernels to run on the Pine64?
It's what is provided by the SoC vendor. There is a community driven mainlining process - see http://linux-sunxi.org/Linux_mainlining_effort for details
Question, if I build a new kernel as per these instructions: https://github.com/longsleep/build-pine6.../README.md
Can I drop in that kernel into this image? Would replacing `Image` be enough, or are there other/more steps involved?
It has been a while and i just released a new Ubuntu build which includes the latest Kernel. No other changes except that also all the other Ubuntu components have been updated to their current repository version.
Download 20160716-1 from https://www.stdin.xyz/downloads/people/l...es/ubuntu/
(07-14-2016, 09:38 AM)bjwschaap Wrote: Question, if I build a new kernel as per these instructions: https://github.com/longsleep/build-pine6.../README.md
If you do not need Kernel modules then replacing the Image file is good enough, else also install the modules with the corresponding script.
  Ubuntu server 20.04 request phi0x 2 11,148 12-30-2020, 08:02 PM
Last Post: phi0x
  Xenial Minimal Image (PINE A64(+)) 0.6.2-77 pineadmin 4 27,613 08-30-2020, 10:35 AM
Last Post: jrronimo
  Kickstarter P64 with LCD, working image? MostHated 1 8,008 01-04-2020, 10:32 AM
Last Post: igorp
  USB Wireless Drivers with Longsleep Linux Kernel jacobscarter 15 41,612 03-06-2019, 02:26 PM
  Allwinner A64 RTC bug fix on bionic image? tkaivola 1 8,549 02-01-2019, 05:09 AM
  SPI on ubuntu IlyaM 4 14,776 07-16-2018, 03:00 AM
Last Post: kingflab
  Ubuntu password not working joemassimino 4 14,381 05-18-2018, 03:33 PM
Last Post: Luke
  How can I get a wireless dongle working on Xenial Desktop latest build Rocklobster 1 6,872 04-16-2018, 03:09 PM
Last Post: Rocklobster
  After flashing Ubuntu- how to get graphical desktop Partymack711 6 17,721 02-01-2018, 09:45 AM
Last Post: Partymack711
  PPTP doesnt work with ubuntu escovedo 2 13,628 08-23-2017, 09:28 AM
Last Post: gilbertotcc
Users browsing this thread: 10 Guest(s)
