Axolotl on PinePhone / Mobian
Question
Hello
Sorry for my basic questions. I would like to be able to create a Signal account without using a phone number or an Android phone and I need to communicate with someone who uses Signal. Does Axolotl work on Trixie? I understand that there are some unimplemented features, I need to send mostly text messages, I don't plan to use groups. Is the project still active?
You need a phone number to create a Signal account. Signal normally sends a verification code via SMS to that number, it can be coaxed into making a voice call instead (accessibility feature, but can be used to register with a landline number). But with no phone number at all, it is not possible, no matter what client you use.
Axolotl did not work at all for me when I tried it a while ago.
People suggest using signal-cli to register and then pairing Flare (or signal-desktop, but that is not designed for touch interfaces at all, so Flare will probably work better) with it. Flare can also experimentally attempt registration by using the FLARE_ENABLE_PRIMARY_DEVICE environment variable, which may or may not work for you. I have not tested that (neither the environment variable nor the signal-cli) because I do not currently have a need for a Signal account.
(06-18-2025, 02:22 PM)anonymous Wrote: Hello
(06-18-2025, 06:09 PM)Kevin Kofler Wrote: You need a phone number to create a Signal account. Signal normally sends a verification code via SMS to that number, it can be coaxed into making a voice call instead (accessibility feature, but can be used to register with a landline number). But with no phone number at all, it is not possible, no matter what client you use.
i use signal-cli and signal-desktop. i usually use laptop or desktop computer mostly anyway. in pinephone, 150% screen scaling or less is recommended for signal-desktop.
i need to test flare at some point.
Thank you for your answers. As I don't want to use my phone number to register, I'll look for another solution and I'll stay away from Signal.
  Mobian MMS/SMS text problem bcnaz 16 39,311 06-23-2026, 06:53 AM
Last Post: mehdy
  Mobian image for the PinePhone Korfou 2 1,776 04-27-2026, 09:57 AM
Last Post: Korfou
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 80 68,848 12-24-2025, 12:11 AM
  cryptocurrency on mobian/pinephone biketool 33 73,631 10-08-2025, 06:21 AM
  XLibre for Mobian Hiraghm 0 3,405 06-29-2025, 12:38 PM
Last Post: Hiraghm
  VoIP account on mobian dialer j_s 0 3,075 06-15-2025, 04:19 PM
Last Post: j_s
  Mobian Pinephone Notification LED biketool 2 4,254 06-07-2025, 03:19 PM
  Vivaldi Web browser nearly native for Mobian biketool 3 5,011 05-06-2025, 02:19 AM
  mobian calamares fail merom 2 4,704 04-29-2025, 02:10 PM
Last Post: mdk
  Pinephone seems tobe using 4G data instead of Wifi data grump_fiddle_reinstall 7 7,936 02-20-2025, 02:47 PM
Last Post: puffchumpy
