NetBSD 1.0 runs down battery
I don't expect the cable knows anything! It's just wires and terminals. I don't know right off hand why it wouldn't have a direct power connection, like the AC adapter power supply that supplies the same 5V.
(11-15-2023, 12:39 PM)donn Wrote: I don't expect the cable knows anything!  It's just wires and terminals.  I don't know right off hand why it wouldn't have a direct power connection, like the AC adapter power supply that supplies the same 5V.
Some cables actually have chips in the plug ends.  USB-C charging is capable of negotiating charge rates, and that must happen (if it does) in the cable or the wall wart that the cable plugs in to.  The PBP does *not* negotiate USB-C charging rates in hardware.  I don't know if Linux might tell a smart charger plugged in to USB to turn on.  But such a device, if that's what's happening, should generate a message when NetBSD does or doesn't recognise it, I expect.
:wq
Ah, I see written on the AC adapter to USB A, DC 5.0V=3A / DC 9V=2A / DC 12V=1.5A
Just to be clear, that feature does greatly speed up charging on devices* that support it, but the PBP does not support it. Even if Linux is negotiating with the adaptor somehow, there's no actual benefit (other than maybe a power supply that needs to be commanded to turn on, such as what might be happening above).
*not in that case, as the current is lower at higher voltages, so no power gain
:wq
  2nd NetBSD boot goes dark donn 6 9,165 02-22-2024, 03:59 AM
  Booting NetBSD untitled 12 19,269 08-30-2022, 01:23 AM
Last Post: untitled
  NetBSD on the Pinebook Pro in August 2022 - or not? KC9UDX 6 11,589 08-24-2022, 01:49 AM
  NetBSD and pinebook keyboard/trackpad firmware updater mrgtwentythree 5 17,583 05-16-2021, 07:37 PM
Last Post: mrgtwentythree
  NetBSD Der Geist der Maschine 76 171,588 05-16-2021, 02:43 PM
Music NetBSD and USB "sound cards" KC9UDX 2 10,557 05-07-2021, 12:11 PM
Last Post: elimark1
Question Issues Installing NetBSD on a PineBook Pro ReleaseTheGeese 14 28,816 01-31-2021, 11:20 AM
  NetBSD -Current binaries BronzeBeard 8 20,757 12-31-2020, 08:38 PM
Last Post: BronzeBeard
Thumbs Up My NetBSD on Pinebook Pro journey KC9UDX 11 28,811 12-06-2020, 08:26 PM
