Booting - User device selection in U-Boot?
All these things you propose can and have be done with u-boot.  For some reason the pinebook pro has an barely functional u-boot with no features.
U-boot has a console, where it's possible to boot specific kernels with custom command lines, mount file systems, copy files between devices, do basic networking like DHCP, ping, tftp load files and mount network drives with NFS.
It can use USB device mode to make the eMMC appear as a flash drive to a host computer connected to the USB port.  Really handy way to repair an eMMC that won't boot, compared to needing to open the pbp up and remove the eMMC module!
You can create scripts to do certain things, e.g. "boot-emmc", "boot-sd", "boot-sdkernel-emmcroot".
There is a menu system that can list boot options and allows selecting one.
It's possible to create an automatic fallback system.  If a kernel fails to boot a certain number of times in a row, then an alternate kernel will be used.  Something run in Linux marks a boot as good when it's reached some point considered good enough, like systemd has finished entering multi-user.target.  Every embedded Linux product I've designed has had something like this.
But the u-boot on the PBP doesn't even have keyboard or fb support, so one can't even seen an error message if it doesn't boot, much less any of the above.
RE: Booting - User device selection in U-Boot? - by xyzzy - 11-18-2020, 06:15 PM
  uboot wont boot to SD card after upgrade jbradley419 7 847 01-19-2024, 02:29 PM
  Video Flashing/adjusting on boot and reboot jbradley419 0 295 01-16-2024, 09:17 AM
Last Post: jbradley419
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 2,246 12-15-2023, 02:11 PM
  PBP won't boot after trying to reinstall Manjaro ARM soupgirl 3 707 12-13-2023, 08:17 PM
Last Post: trillobite
  Various freezes during boot & while running several Linux distros - hardware error? donuts 1 593 11-22-2023, 11:47 AM
Last Post: fxc
  Cannot boot to Kali SD card after uboot upgrade jbradley419 4 1,190 09-19-2023, 08:48 AM
Last Post: dachalife
  Does latest Tow-Boot install/work correctly for everyone? tophneal 4 1,889 08-03-2023, 03:30 PM
  Boot into NVME drive, no wifi, sound, buttons... PaulQ 0 808 07-13-2023, 01:50 PM
Last Post: PaulQ
  New Pinebook pro won’t boot Generaltuxenburg 4 1,953 06-14-2023, 07:20 AM
  Followed the blog post to install Fedora: PBP not booting anymore koenigs 6 1,894 06-01-2023, 10:58 AM
