Digitizer is on when screen is off
(08-19-2020, 03:11 AM)dukla2000 Wrote:
(08-17-2020, 04:05 PM)klick Wrote: I am also having an issue with the phone waking up and the screen staying on for extended periods without any external input. There does not appear to be any notifications that I can find. It wakes up for about one minute then shuts off.
I also still have this - seems to be after the OS has been booted for a while. Often times a reboot seems to settle things. Which means (my amateurish debugging) there is some process that can get started after some use that keeps waking the screen for whatever reason.
For me, the battery seems to drain faster on Mobian than UBports UT. I assume the screen wake contributes to this issue. Since you are using it as a daily driver, how do you manage this? Regular charging or using a spare battery?
PinePhone UBports CE and Mobian on SD, Mint Mobile, Pinebook Pro Manjaro
Digitizer is on when screen is off - by dukla2000 - 05-02-2020, 03:18 PM
RE: Digitizer is on when screen is off - by heng - 06-03-2020, 06:07 AM
RE: Digitizer is on when screen is off - by heng - 06-03-2020, 12:28 PM
RE: Digitizer is on when screen is off - by a-wai - 06-05-2020, 04:46 PM
RE: Digitizer is on when screen is off - by a-wai - 06-11-2020, 05:46 AM
RE: Digitizer is on when screen is off - by klick - 08-17-2020, 04:05 PM
RE: Digitizer is on when screen is off - by klick - 08-19-2020, 10:56 AM
RE: Digitizer is on when screen is off - by klick - 08-21-2020, 01:42 PM
  Screen auto-rotation sensitivity mdk 0 268 12-26-2023, 06:08 AM
Last Post: mdk
  Screen stay black unless power key pressed short freelectro 0 652 06-24-2023, 01:55 PM
Last Post: freelectro
  Unsuspend → Black screen mdk 15 5,205 06-22-2023, 11:20 AM
Last Post: Melechtna
  Lock screen question: always squeekboard tuxcall 1 1,233 02-02-2023, 08:51 PM
Last Post: Haibara23
  [solved] Black screen at boot time mdk 0 1,017 01-13-2023, 03:33 AM
Last Post: mdk
  how to split screen? andrew907 2 1,531 08-08-2022, 09:38 AM
Last Post: andrew907
  Proximity sensor is oversensitive (was "Screen blanks when making call") treebeard 5 2,812 08-02-2022, 03:16 PM
Last Post: treebeard
  on screen keyboard woes vusra 1 1,250 07-18-2022, 03:29 AM
Last Post: vusra
  Giving certain audio apps priority on the lock screen and pulldown 3x5co 0 853 07-17-2022, 10:34 AM
Last Post: 3x5co
  Won't boot, black screen mdk 4 2,735 07-03-2022, 06:38 PM
Last Post: Chief
