WiFi 6 for the Pinebook Pro
(04-24-2020, 02:14 AM)tsys Wrote:
(04-23-2020, 03:46 PM)xmixahlx Wrote: AWESOME
Are any other uses tested/planned/brainstormed?
Yes, we are currently planning a second revision of the board that allows using both a M.2 WiFi card and a NVMe SSD. That version will likely have an additional power header where you can plug in the jumper cable from the battery. That should also solve the NVMe power issues observed when powering certain SSDs from the onboard 3.3 V regulator.
Making it even cooler!
Any expectations as to how that might impact the battery's charge level during use?
WiFi 6 for the Pinebook Pro - by tsys - 04-23-2020, 01:53 PM
RE: WiFi 6 for the Pinebook Pro - by MIchael - 04-23-2020, 02:54 PM
RE: WiFi 6 for the Pinebook Pro - by xmixahlx - 04-23-2020, 03:46 PM
RE: WiFi 6 for the Pinebook Pro - by tsys - 04-24-2020, 02:14 AM
RE: WiFi 6 for the Pinebook Pro - by tophneal - 04-24-2020, 07:37 AM
RE: WiFi 6 for the Pinebook Pro - by gplanansky - 05-31-2020, 03:53 PM
RE: WiFi 6 for the Pinebook Pro - by Luke - 04-24-2020, 10:27 AM
RE: WiFi 6 for the Pinebook Pro - by pfeerick - 04-25-2020, 04:10 AM
RE: WiFi 6 for the Pinebook Pro - by Luke - 04-25-2020, 05:56 AM
RE: WiFi 6 for the Pinebook Pro - by evilbunny - 04-25-2020, 06:04 AM
RE: WiFi 6 for the Pinebook Pro - by rossk - 04-24-2020, 02:14 PM
RE: WiFi 6 for the Pinebook Pro - by manawyrm - 04-24-2020, 05:27 PM
RE: WiFi 6 for the Pinebook Pro - by xmixahlx - 04-24-2020, 04:42 PM
RE: WiFi 6 for the Pinebook Pro - by pfeerick - 04-28-2020, 12:19 AM
RE: WiFi 6 for the Pinebook Pro - by Arwen - 06-04-2020, 07:35 PM
RE: WiFi 6 for the Pinebook Pro - by diodelass - 06-04-2020, 09:21 PM
RE: WiFi 6 for the Pinebook Pro - by User 11436 - 06-11-2020, 04:11 AM
RE: WiFi 6 for the Pinebook Pro - by manawyrm - 06-14-2020, 06:09 AM
  HDMI or VGA From Pinebook Pro via Pinebook Pro Docking Deck? segaloco 2 550 04-09-2024, 04:33 AM
Last Post: maxjrh
  Pinebook Pro on Debian 12 Power Issue u974615 1 347 03-13-2024, 10:46 AM
Last Post: u974615
  Pinebook Pro Source for Trackpad Flex / Ribbon Cable rankharris 1 290 02-17-2024, 07:06 PM
  Pinebook Pro charging issues tomekdev 1 628 01-05-2024, 08:40 PM
Last Post: tomekdev
  Kernel Not Detecting Wifi tallfrye 10 1,051 01-01-2024, 06:57 AM
  Replacement battery for PineBook Pro DrYak 3 1,111 11-07-2023, 10:09 AM
Last Post: DrYak
  Pinebook Pro Revised Keyboard Firmware jackhumbert 73 130,748 09-13-2023, 03:43 AM
Last Post: k3dAR
  PineBook Pro dead ottahe 9 6,050 01-18-2023, 07:41 PM
Last Post: ottahe
  Pinebook Pro malfunctioned hardware samtux 10 4,451 12-27-2022, 03:31 PM
Last Post: samtux
  PineBook Pro revision 2.2: Wishlist for the hardware issue fixes dsimic 115 136,881 11-30-2022, 04:28 PM
