Netflix, state of the art?
#79
(09-26-2020, 12:05 PM)wrzomar Wrote:
(09-10-2020, 03:36 AM)3xC0MM Wrote:
Quote:Please do
sudo pacman -Rnsc chromium-docker
sudo pacman -S chromium-docker
First command will remove all the old chromium-docker content while second one will install it fresh.
Hope this will solve your issue.
Thank you, that was it!
Quote:UPDATE:
Added pulseaudio handling over network so paprefs becomes a dependency which will be installed but user will have to enable it
Open paprefs - sound server preference
and just enable as per the below pic.
You mention this in the post above, but the picture does not show. Can you please repost it?
BR
Also, if someone has enabled the firewall, they will have to allow TCP connections to port 4713 from docker subnet. For ufw it would be:
sudo ufw allow proto tcp to any port 4713 from `docker network inspect bridge --format='{{(index .IPAM.Config 0).Subnet}}'`
PS. I've changed the addrip variable in the chromium-armhf script to the docker gateway address. As long as docker0 interface is up, audio should work. Now the line looks like this:
addrip="$(docker network inspect bridge --format='{{(index .IPAM.Config 0).Gateway}}')"
PPS. To decode this image you need to copy everything between '[img]data:image/png;base64,' and '[/img]', paste it to text editor and save it, then use base64 command to decode.
It shows PulseAudio Preferences window with Network Server tab opened, 'Enable network access to local sound devices' and 'Don't require authentication' options are checked.
PPPS. I've installed Manjaro on emmc a few days ago, Spikerguy's post about updating to Chromium 84 is month old but I've just checked Chromium version and it says it's 78 but the base is bionic. Do I have to switch branch to testing or unstable to get this update?
Here is proof:
Chromium-docker package details
About Chromium page
@spikerguy, Where is this updated Chromium? The installed version keeps complaining about upgrading to a newer version.
I've tried updating the chromium but it widevine doesn't support newer version of chromium, we're dependent on ChromeOS to update their widevine to support latest version of chromium.
I can try it in the coming week to see if I can get a newer version of chromium to work with the ChromeOS widevine but I will need someone to share a Netflix or amazon account for testing as I've stopped mine and can no longer get a few trial too Sad
Manjaro ARM Team.
Netflix, state of the art? - by gleachkr - 04-17-2020, 11:27 AM
Netflix, state of the art? - by hthiemann - 04-18-2020, 01:48 AM
RE: Netflix, state of the art? - by PakoSt - 04-18-2020, 07:47 AM
RE: Netflix, state of the art? - by gleachkr - 04-18-2020, 10:11 AM
Netflix, state of the art? - by hthiemann - 04-19-2020, 01:14 PM
RE: Netflix, state of the art? - by PakoSt - 04-19-2020, 04:18 PM
RE: Netflix, state of the art? - by Eight Bit - 04-20-2020, 11:37 AM
RE: Netflix, state of the art? - by 8-bit - 04-19-2020, 05:42 PM
RE: Netflix, state of the art? - by PakoSt - 04-19-2020, 06:44 PM
RE: Netflix, state of the art? - by hthiemann - 04-20-2020, 12:41 PM
RE: Netflix, state of the art? - by spikerguy - 04-20-2020, 03:54 PM
RE: Netflix, state of the art? - by Luke - 04-20-2020, 03:57 PM
RE: Netflix, state of the art? - by PakoSt - 04-20-2020, 01:41 PM
RE: Netflix, state of the art? - by PakoSt - 04-20-2020, 05:59 PM
RE: Netflix, state of the art? - by appelgriebsch - 04-23-2020, 01:29 AM
RE: Netflix, state of the art? - by hthiemann - 04-21-2020, 12:56 AM
RE: Netflix, state of the art? - by Eight Bit - 04-22-2020, 07:47 AM
RE: Netflix, state of the art? - by hthiemann - 04-23-2020, 01:55 AM
RE: Netflix, state of the art? - by PakoSt - 04-23-2020, 06:10 AM
RE: Netflix, state of the art? - by appelgriebsch - 04-23-2020, 10:47 AM
RE: Netflix, state of the art? - by PakoSt - 04-23-2020, 05:56 PM
RE: Netflix, state of the art? - by PakoSt - 04-24-2020, 02:29 AM
RE: Netflix, state of the art? - by hthiemann - 04-24-2020, 07:17 AM
RE: Netflix, state of the art? - by PakoSt - 04-24-2020, 01:43 PM
RE: Netflix, state of the art? - by spikerguy - 04-24-2020, 03:26 PM
RE: Netflix, state of the art? - by hthiemann - 04-25-2020, 05:12 AM
RE: Netflix, state of the art? - by gleachkr - 04-25-2020, 12:58 PM
RE: Netflix, state of the art? - by PakoSt - 04-25-2020, 02:01 PM
RE: Netflix, state of the art? - by PakoSt - 04-26-2020, 04:13 AM
RE: Netflix, state of the art? - by spikerguy - 04-26-2020, 08:00 AM
RE: Netflix, state of the art? - by PakoSt - 04-26-2020, 03:18 PM
RE: Netflix, state of the art? - by gleachkr - 04-26-2020, 04:09 PM
RE: Netflix, state of the art? - by spikerguy - 04-27-2020, 12:02 PM
RE: Netflix, state of the art? - by gleachkr - 04-28-2020, 01:10 PM
RE: Netflix, state of the art? - by spikerguy - 04-30-2020, 07:05 AM
RE: Netflix, state of the art? - by spikerguy - 04-30-2020, 04:58 PM
RE: Netflix, state of the art? - by pfeerick - 05-01-2020, 03:02 AM
RE: Netflix, state of the art? - by whiskey - 05-02-2020, 12:29 PM
RE: Netflix, state of the art? - by kervel - 05-28-2020, 01:58 PM
RE: Netflix, state of the art? - by appelgriebsch - 07-16-2020, 01:26 AM
RE: Netflix, state of the art? - by mkdent - 07-17-2020, 10:26 PM
RE: Netflix, state of the art? - by appelgriebsch - 07-18-2020, 12:24 AM
RE: Netflix, state of the art? - by TonGruter - 07-28-2020, 02:27 PM
RE: Netflix, state of the art? - by spikerguy - 07-30-2020, 12:03 PM
RE: Netflix, state of the art? - by TheBackburner - 08-09-2020, 02:48 PM
RE: Netflix, state of the art? - by spikerguy - 08-14-2020, 06:28 AM
RE: Netflix, state of the art? - by appelgriebsch - 09-06-2020, 11:42 PM
RE: Netflix, state of the art? - by User 18041 - 09-09-2020, 08:44 AM
RE: Netflix, state of the art? - by spikerguy - 09-09-2020, 11:45 AM
RE: Netflix, state of the art? - by User 18041 - 09-10-2020, 03:36 AM
RE: Netflix, state of the art? - by wrzomar - 09-26-2020, 12:05 PM
RE: Netflix, state of the art? - by spikerguy - 10-11-2020, 04:04 AM
RE: Netflix, state of the art? - by PakoSt - 05-02-2020, 04:08 PM
RE: Netflix, state of the art? - by whiskey - 05-02-2020, 06:31 PM
RE: Netflix, state of the art? - by whiskey - 05-02-2020, 06:54 PM
RE: Netflix, state of the art? - by pfeerick - 05-03-2020, 06:17 AM
RE: Netflix, state of the art? - by whiskey - 05-03-2020, 08:02 AM
RE: Netflix, state of the art? - by Eight Bit - 05-03-2020, 09:28 AM
RE: Netflix, state of the art? - by spikerguy - 05-03-2020, 06:48 PM
RE: Netflix, state of the art? - by pfeerick - 05-04-2020, 06:39 AM
RE: Netflix, state of the art? - by spikerguy - 05-04-2020, 10:35 AM
RE: Netflix, state of the art? - by Eight Bit - 05-04-2020, 03:42 PM
RE: Netflix, state of the art? - by spikerguy - 05-06-2020, 02:19 AM
RE: Netflix, state of the art? - by Eight Bit - 05-07-2020, 03:48 AM
RE: Netflix, state of the art? - by spikerguy - 05-08-2020, 07:38 AM
RE: Netflix, state of the art? - by spikerguy - 05-20-2020, 10:25 PM
RE: Netflix, state of the art? - by Luke - 05-21-2020, 04:26 AM
RE: Netflix, state of the art? - by erchache2000 - 05-22-2020, 04:24 PM
RE: Netflix, state of the art? - by koparthur - 05-31-2020, 08:41 AM
RE: Netflix, state of the art? - by spikerguy - 05-31-2020, 02:12 PM
RE: Netflix, state of the art? - by koparthur - 05-31-2020, 03:55 PM
RE: Netflix, state of the art? - by spikerguy - 06-01-2020, 05:08 AM
RE: Netflix, state of the art? - by mkdent - 07-18-2020, 02:53 AM
RE: Netflix, state of the art? - by mkdent - 07-18-2020, 03:59 AM
RE: Netflix, state of the art? - by appelgriebsch - 07-18-2020, 04:37 AM
RE: Netflix, state of the art? - by mkdent - 07-18-2020, 07:40 AM
RE: Netflix, state of the art? - by wrzomar - 10-13-2020, 06:11 AM
RE: Netflix, state of the art? - by Mangled - 10-27-2020, 10:20 AM
RE: Netflix, state of the art? - by monty11ez - 11-25-2020, 05:28 PM
RE: Netflix, state of the art? - by wrzomar - 03-24-2021, 03:42 PM
  Funny Conky like script to monitor your PBP state as400 1 3,278 08-19-2020, 12:57 PM
Last Post: xmixahlx
  Netflix on default Chromium/Debian MoonDog 8 10,155 01-28-2020, 04:58 AM
Last Post: simeon
  State of hibernate or hybrid-sleep? Arwen 5 7,433 11-21-2019, 07:51 AM
