Mr. Fixit Script Manual Update + MicroSD Boot help
(04-11-2020, 11:15 AM)mlentink Wrote:
(04-04-2020, 05:57 PM)SageFox Wrote: And I have once again figured out the issue: I was not using the emmc version of the bootable image, it was buried somewhere on the internets.
Then perhaps you can help me as well. Because shouldn't the PBP be able to boot from sdcard directly? I'm assuming you're implying you're installing to the eMMC from the sdcard? I'd be interested to know which image you were installing and where you got it, so I might try the same.
Thanks in advance!
I suggest you get Manjaro 20.04, the new default for the Pinebook Pro.
https://forum.manjaro.org/t/manjaro-arm-...sed/133374
https://osdn.net/projects/manjaro-arm/st...sma/20.04/
RE: Mr. Fixit Script Manual Update + MicroSD Boot help - by jiyong - 04-11-2020, 02:32 PM
  uboot wont boot to SD card after upgrade jbradley419 7 850 01-19-2024, 02:29 PM
  Video Flashing/adjusting on boot and reboot jbradley419 0 297 01-16-2024, 09:17 AM
Last Post: jbradley419
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 2,248 12-15-2023, 02:11 PM
  PBP won't boot after trying to reinstall Manjaro ARM soupgirl 3 708 12-13-2023, 08:17 PM
Last Post: trillobite
  Various freezes during boot & while running several Linux distros - hardware error? donuts 1 593 11-22-2023, 11:47 AM
Last Post: fxc
  Cannot boot to Kali SD card after uboot upgrade jbradley419 4 1,190 09-19-2023, 08:48 AM
Last Post: dachalife
  After update, multiple problems, pinebook pro. jd50i 1 1,054 09-16-2023, 09:41 AM
Last Post: jd50i
  Does latest Tow-Boot install/work correctly for everyone? tophneal 4 1,892 08-03-2023, 03:30 PM
  Boot into NVME drive, no wifi, sound, buttons... PaulQ 0 810 07-13-2023, 01:50 PM
Last Post: PaulQ
  New Pinebook pro won’t boot Generaltuxenburg 4 1,958 06-14-2023, 07:20 AM
