Serial port cable
As I would like to debug suspend problem over serial cable, and as I only have the one from pine64 store, it should be really clarified before suggesting that "should works :-)" . If one kills his PBP because of this, will it get replaced free of charge? As coronavirus ban is there, receiving new PBP is almost impossible.
Other than this what is an alternative? To use some kind of jack headphone cable and connect to an USB to TTL Converter with 3.3V? But ifrk3399 uarts want 3.0V (max 3.15) what to do?
Serial port cable - by bsammon - 03-06-2020, 04:11 PM
RE: Serial port cable - by tllim - 03-09-2020, 06:00 PM
RE: Serial port cable - by z4v4l - 03-09-2020, 07:06 PM
RE: Serial port cable - by danielt - 03-10-2020, 02:16 AM
RE: Serial port cable - by zaius - 03-10-2020, 11:56 AM
RE: Serial port cable - by danielt - 03-11-2020, 08:53 AM
RE: Serial port cable - by zaius - 03-11-2020, 01:00 PM
RE: Serial port cable - by danielt - 03-11-2020, 02:41 PM
RE: Serial port cable - by zaius - 03-13-2020, 12:37 PM
RE: Serial port cable - by danielt - 03-16-2020, 08:18 AM
RE: Serial port cable - by zaius - 03-16-2020, 12:44 PM
RE: Serial port cable - by vrabac - 03-10-2020, 12:25 AM
RE: Serial port cable - by z4v4l - 03-11-2020, 03:37 PM
RE: Serial port cable - by danielt - 03-12-2020, 04:48 AM
RE: Serial port cable - by xyzzy - 11-18-2020, 09:59 PM
RE: Serial port cable - by mattpenn - 03-03-2021, 08:32 AM
RE: Serial port cable - by tllim - 03-04-2021, 12:49 AM
RE: Serial port cable - by mattpenn - 03-04-2021, 10:00 AM
  serial cable 2023 thread bsammon 2 2,690 07-20-2023, 10:13 AM
Last Post: bsammon
  How are people finding the type-A USB 3.0 port? chris88233 1 1,820 10-01-2022, 01:04 AM
Last Post: LivingLinux
  Fried the charger port and USB leapylee 1 2,533 01-12-2022, 03:32 AM
Last Post: Danct12
  Pinebook Pro - Display cable broken? snokis 0 2,208 08-17-2021, 11:30 AM
Last Post: snokis
  [SOLVED] Red light flashes next to barrel-port Carl 31 57,166 01-18-2021, 09:34 AM
Last Post: dsimic
  Serial console accessible from outside as400 4 6,982 10-23-2020, 11:21 AM
Last Post: as400
  Pinebook Pro doesn't boot most of the time unless connected via USB-serial! nib0 16 19,019 09-29-2020, 10:24 PM
  Charging via USB-C Port tyha 15 26,043 07-22-2020, 08:15 PM
Last Post: iscmob
  Save your sanity: If you buy a PBP, buy a serial adapter and USB to eMMC adapter. Syonyk 11 16,770 06-30-2020, 10:28 AM
Last Post: manawyrm
Photo Looking for a PBP NVMe/SSD cable ab1jx 13 18,729 06-07-2020, 01:24 PM
Last Post: ab1jx
