Repeatedly Freezing then Rebooting
After power on it keeps locking up before this happens if you are at a command line you can press keys and the cursor blinks to the keypress but nothing appears and then it freezes.  This happens about 1 minute after been switched on and repeatedly does this while left on.
I'm still using the default disto I did disable lightdb just in case it was GUI related but it happens at a command line as well.  This started happening after I ran updates a few weeks back but I've not been using it so only just realised its consistently doing this.
Any ideas what's going on? or how to find out?
(I am actually wanting to wipe it and put manjaro on but can't get it to boot SD or USB either)
Repeatedly Freezing then Rebooting - by Dreamwalker - 02-18-2020, 11:51 AM
Lightbulb Wifi Privacy Switch without rebooting DrYak 8 18,255 06-20-2020, 03:44 AM
Last Post: robt
  Earlyoom: kill process before freezing regivanx 0 1,626 05-23-2020, 01:50 PM
Last Post: regivanx
