New Phosh image - first impressions
#42
(03-06-2020, 07:40 AM)PureTryOut Wrote: Make sure you use sudo. Also, are you sure you have a working internet connection?
Yes, I should have made that clear. I do use sudo of course.
As to the working connection, I'm a lot less clear. I was pretty sure I had one yesterday, when I was trying that. This morning, on coming back from suspend, I don't.
I'll reboot and see what I get.
A bit later: hmph. Nope. Now I can't get any connection at all. The gui Settings is more responsive than it used to be, but still has the important buttons offscreen so I can't use that. I tried
sudo ofonoctl poweron
sudo ofonoctl online
and it said the modem was on and doing its thing, but no icons appear confirming that. Since I get my internet connection via cellular provider, that's a problem.
I also tried to get on a wifi connection in the house but, again, the dialog boxes are mostly offscreen. And :redface: I can't readily find the cli way of hopping on.
I think maybe what I need is a kind soul to re-summarize all the commands to do this. Maybe the currently valid ones could be in a sticky at the top of the threads on the PMOS forum?
OS: Mobian Bookworm, Phosh. Pinephone Braveheart from 2020-02-11
RE: New Phosh image - first impressions - by hex - 02-18-2020, 07:42 AM
RE: New Phosh image - first impressions - by undo - 02-20-2020, 04:14 AM
RE: New Phosh image - first impressions - by pjsf - 02-21-2020, 12:30 AM
RE: New Phosh image - first impressions - by quixote - 03-06-2020, 10:38 AM
  Fresh install pmos+phosh does not boot user641 1 571 10-08-2023, 04:04 AM
Last Post: user641
  [Not Pinephone] Phosh Autologin LienRag 11 2,285 09-01-2023, 10:55 PM
Last Post: rocket2nfinity
  pmos/phosh edge update and audio disappears robthebold 9 5,673 07-10-2022, 03:26 AM
Last Post: arkadione
  How to delete single sms in phosh? bircoph 1 1,404 07-06-2022, 08:10 AM
Last Post: bircoph
  no screen rotation on pinephone pro with postmarketOS + phosh elode 2 2,748 07-03-2022, 09:13 AM
Last Post: a.h.littorin
  closing apps rather than leaving them running (phosh) lordearl 7 6,323 02-03-2022, 09:14 PM
Last Post: parry
  Application list PMOS-Phosh jmorris 6 6,255 12-04-2021, 02:26 AM
Last Post: Juergen
  Phosh beta 10, no send button on Chatty? Rainer 0 1,651 05-24-2021, 08:17 AM
Last Post: Rainer
  Where is the original PM OS image for Pinephone? mw4jet 1 2,659 03-14-2021, 07:37 AM
Last Post: ludix
  PMOS test image: failed EG25 test broke modem fw MtnSk8 4 5,787 02-28-2021, 02:20 PM
Last Post: MtnSk8
