3D Printing a Pinephone Back Cover
#23
(03-27-2021, 01:43 AM)dgdimick Wrote: Anyone have any type of update here?
I've got a few FDM printers and looking to try custom back cases.
I know that a few of the problems that have been identified are solvable, things like tabs should be able to be fixed by just adjusting the layer resolution, normally people print at .20mm or about that, and I've learned that for the really "good" prints I want to use, I'll lower the layer height to as low as .12mm, and even .08mm - It takes a LONG time to print, however, the quality is worth it.
I haven't done anything on my side...
My 3D printer is much too old and not calibrated enough for such tiny details. What I was thinking about was to forego the snapping tabs, and instead use the threaded holes used to fasten the inner mid frame to the front cover. In other words, make corresponding countersunk or counterbore holes on the back cover. But I would need to source longer screws, and find out what size and thread they are. Of course by doing this, I would need to make removable access panels for the battery, the SIM/SD slots and the dip switches. Sliding, hinged, not sure... This may make the back cover a lot thicker.
3D Printing a Pinephone Back Cover - by sundog - 02-16-2020, 11:11 AM
RE: 3D Printing a Pinephone Back Cover - by NormandC - 03-28-2021, 10:29 PM
  Case for Pinephone totilele 13 7,665 04-11-2024, 11:48 AM
Last Post: gramonyl
  PinePhone Dock with laptop? Mikey1977Y2J 2 681 12-12-2023, 05:43 PM
Last Post: Mikey1977Y2J
  Update the PinePhone keyboard driver to support missing characters? Peter Gamma 8 8,309 10-22-2023, 08:43 PM
Last Post: Peter Gamma
  key repeat with pinephone keyboard rotwang 0 481 10-22-2023, 03:39 PM
Last Post: rotwang
  Pinephone with mini keyboard, trackpad and large power bank? Peter Gamma 0 550 10-21-2023, 07:50 AM
  Use the Linux Console with the PinePhone Keyboard mburns 2 1,074 10-20-2023, 04:11 PM
Last Post: mburns
  Mouse for the PinePhone? Peter Gamma 21 15,686 10-04-2023, 10:24 AM
  PinePhone Wallet Case Shane 5 5,115 09-17-2023, 12:52 PM
Last Post: J T
  KB: Using bus powered USB peripherals with the pinephone keyboard mounted docsunset 9 38,077 08-07-2023, 06:12 AM
Last Post: mikeb
  PinePhone flex breakout board with Grove female header jnpine 0 663 08-04-2023, 10:47 PM
Last Post: jnpine
