What is default password?
You've not wasted your money - if all else fails you can reinstall the OS using an SD card. If you don't have anything important on the tablet yet then this is probably the easiest option, and will make sure you're fully up to date too. See https://wiki.pine64.org/wiki/PineTab#Operating_Systems for options, and installation instructions below that. If you want to try resetting the password you'll probably want to boot from SD card anyway and use the chroot method - I've not tried it on a PinePhone or PineTab but there are multiple generic guides if you search for 'linux chroot password reset' to point you in the right direction. Someone here might have an easier alternative though.
For future reference you've posted this in the PinePhone section of the forum rather than the PineTab one. For this query it doesn't make much difference, but for other queries it might.
What is default password? - by quixote - 02-13-2020, 10:26 PM
RE: What is default password? - by wibble - 02-13-2020, 10:42 PM
RE: What is default password? - by quixote - 02-13-2020, 11:23 PM
RE: What is default password? - by PureTryOut - 02-20-2020, 06:03 AM
RE: What is default password? - by K_Research - 09-09-2020, 10:28 AM
RE: What is default password? - by jeem - 11-02-2020, 01:00 PM
RE: What is default password? - by wibble - 11-03-2020, 08:55 AM
  Firefox Crashes on Start-up (latest installer) & How do I change Default Browser? aLoop100o 1 429 11-22-2023, 10:16 AM
Last Post: zetabeta
  Unable to set default apps Barugon 7 3,384 12-04-2022, 12:28 PM
Last Post: alaraajavamma
  Help with ssh and setting default apps jojuma 2 1,694 09-10-2022, 07:55 AM
Last Post: jojuma
  What is the default pin!? ThatWasLeftHanded 3 5,479 09-08-2021, 09:01 AM
Last Post: walter1950
  Password manager skaf2007 4 4,817 11-10-2020, 04:20 PM
Last Post: User 18618
  Disabe Bluetooth by default Alejandro.SU 1 2,587 11-09-2020, 10:59 AM
Last Post: Lousy Fisherman
  Terminal password difficulty Hobbes42 2 3,355 10-18-2020, 08:24 AM
Last Post: Hobbes42
  Bug: When you initially boot it does not bring up the password screen realrichardsharpe@gmail.com 5 6,348 02-12-2020, 11:58 PM
Last Post: pjsf
