A quick tutorial on having the image work its best
#25
(02-15-2020, 12:53 PM)blicken Wrote: well, doing apt-get install update, ends in:
Errors were encountered while processing:
bluez
ubuntu-system-settings
unity8
which could be why im having issues... or thats what I thought.
the first error generated was:
insserv: can not stat(../rc3.d/): Structure needs cleaning
which is from a dirty filesystem. I cloned the Ubuntu ports image directly, and did not then also run fack.etx4 /dev/mmcbk0p1 against the unmounted filesystem.
I havent looked at the scripts for cloning, I just used ddrescue, but in either case, maybe the ports image should get filesystem checked prior to being distributed.
IDK, is that a PinePhone image issue, or an Ubuntu Ports issue?
anyway, fsck your boot disk prior to booting, the ubuntu ports image isnt clean.
Seems more like a write error tbh. If the image was unclean in and of itself more people would have these issues.
re: amixer not working - by curtvaughan - 02-15-2020, 09:03 AM
  Sound won’t work LMalilil 2 3,967 07-28-2020, 09:52 AM
Last Post: Cree
  wifi does not work - authentication problem? pphone-newbie 7 9,011 07-26-2020, 01:30 PM
Last Post: Cree
  dropdown menu doesn't work daniel 3 4,752 07-22-2020, 01:17 PM
Last Post: natasha
  Tutorial for new UBPorts CE users / list of known issues? ThatGeoGuy 2 4,763 07-21-2020, 05:54 PM
Last Post: natasha
  Image #58 Touchscreen Unresponsive BryWilson 3 5,573 06-27-2020, 02:38 AM
Last Post: Zweitaktmotor
  Does Miracast work? mercrapper 1 3,108 06-25-2020, 08:18 AM
Last Post: heng
  Image build guide? Djhg2000 3 5,734 06-18-2020, 02:04 PM
Last Post: bingo600
  Only the top few rows of pixels work on stable OTA 3 NoraCodes 0 2,001 06-18-2020, 09:18 AM
Last Post: NoraCodes
  Battery issues with latest image ashley123 6 8,203 06-14-2020, 11:06 AM
Last Post: KeithMcN
  Ubports OTA won't work on my braveheart none 12 14,870 06-13-2020, 03:23 AM
Last Post: tsar_chasm
