i3status issues reading battery status
(01-20-2020, 04:08 PM)dummy Wrote: So, finally had the time to sit down and try to whip this thing into shape since getting it, so far solid hardware and no more issues than I would have expected with a product like this. But after getting i3 set up, I cannot get the status display to read the battery charge status. At first assumed it was just the normal issue with non-standard battery names, but after manually putting the path in the i3status.conf I'm now getting an error:
no '%d' in battery path
Has anyone else had this issue/have a resolution? I've seen a lot of people playing with i3 setups on here, so hoping someone else's past struggles found the solution.
I have the same issue.  I can not get the battery to display in the i3bar. I have tried using both battery 0 and battery 1 as the labels in my i3status config file. (below) but nothing seams to work.  Not sure if this is a issue with i3 or with the pinebook pro....?
i3status config:
battery 0 {
  format = " %status %percentage %remaining "
  format_down = " no battery "
  last_full_capacity = false
  integer_battery_capacity = true
  hide_seconds = true
  status_chr = "⚡"
  status_bat = "☉"
  status_full = "☻"
  low_threshold = 10
  threshold_type = percentage
  path = "/sys/class/power_supply/rk-bat/uevent"
i3status issues reading battery status - by dummy - 01-20-2020, 04:08 PM
RE: i3status issues reading battery status - by cbk - 01-25-2020, 02:09 AM
  Manjaro [ARM Stable Update] 2021-07-23 issues Bocanila 1 2,061 08-21-2023, 09:10 PM
Last Post: vanessadonald
  Hibernation and Speaker Sound Issues, First Month of PBP kebab 7 3,067 11-02-2022, 02:33 PM
Last Post: kebab
  Any chance of fixing the audio issues on the new batch PBP(it can't be just me...) crazyquark 0 778 09-30-2022, 10:15 AM
Last Post: crazyquark
  Fedora 33 to 34 upgrade issues tydeman 2 2,526 12-02-2021, 02:43 AM
Last Post: linuxfreund
  Battery gauge issue (mainline kernel) lfourquaux 4 5,058 05-22-2021, 02:43 PM
Last Post: jiyong
  eMMC frequently not found by Linux kernel (especially on low battery) v-man 14 16,851 05-14-2021, 01:18 PM
Last Post: djhnsn
  Battery charge threshold xNix 1 2,226 04-17-2021, 07:13 AM
Last Post: Damon
Question Manjaro arm + sway - battery indicator broken mfashby 6 6,828 02-20-2021, 04:07 AM
Last Post: mfashby
  Manjaro Issues: Dark Screen & Font size Sally2 1 3,029 12-19-2020, 03:33 PM
Last Post: wove
  Status stonepound 0 1,631 11-18-2020, 01:35 PM
Last Post: stonepound
