PBP Hardware Issues
(04-17-2020, 12:56 PM)leibide Wrote: Here's a new potential problem, but one with a happy ending:
I ran the battery down so low that the laptop wouldn't charge from the barrel connector. I left it plugged in all night but to no avail. The charging light would not come on and the charger stayed cold. Eventually, I tried charging from the USB type C port, and to my great relief the charging light began to flicker. Now it's charging from the barrel connector and the charging light is staying on. It''s unlikely anyone else will discharge their battery so much that they will experience this problem though. It happened to me after a number of botched and aborted installs while not charging.
UPDATE: Barrel connector charging port doesn't work at all any more. I must have damaged it. I do not remember pulling the charging cable at an awkward level though. The USB type C port still charges just fine, so it's not really a problem.
The charger that came with my ANSI PBP this year has a bad connection to the US plug adapter,  so it was only working intermittently and then quit completely...
   ( The spring loaded contact did not have the spring or just stuck in place )
 I use ether a usb-c charger or the charger from my previous ISO PBP.....
  I did not want to go through the warranty process..
Perhaps your charger has the same flaw  ?
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
PBP Hardware Issues - by zaius - 01-16-2020, 01:19 PM
RE: PBP Hardware Issues - by wasgurd - 01-16-2020, 05:36 PM
RE: PBP Hardware Issues - by mamboman777 - 01-17-2020, 12:49 PM
RE: PBP Hardware Issues - by multi.flexi - 01-22-2020, 03:35 AM
RE: PBP Hardware Issues - by as400 - 01-17-2020, 03:14 PM
RE: PBP Hardware Issues - by Gazoche - 01-20-2020, 06:09 PM
RE: PBP Hardware Issues - by mamboman777 - 01-20-2020, 06:15 PM
RE: PBP Hardware Issues - by gandlers - 01-21-2020, 02:17 AM
RE: PBP Hardware Issues - by xmixahlx - 01-22-2020, 11:54 PM
RE: PBP Hardware Issues - by Bloris - 01-24-2020, 04:29 AM
RE: PBP Hardware Issues - by wtdonnelly - 01-25-2020, 08:40 PM
RE: PBP Hardware Issues - by Bloris - 01-29-2020, 06:21 AM
RE: PBP Hardware Issues - by bigCamel - 03-11-2020, 06:20 AM
RE: PBP Hardware Issues - by leibide - 04-17-2020, 12:56 PM
RE: PBP Hardware Issues - by bcnaz - 04-18-2020, 08:24 AM
RE: PBP Hardware Issues - by leibide - 04-22-2020, 12:29 PM
RE: PBP Hardware Issues - by zaius - 04-27-2020, 12:00 PM
  New Hardware names_mark_ 1 237 04-23-2024, 08:41 AM
Last Post: dachalife
  Pinebook Pro charging issues tomekdev 1 633 01-05-2024, 08:40 PM
Last Post: tomekdev
  Hardware makes a strange pop noise. Gemeindepirat 7 3,036 08-12-2023, 01:59 AM
Last Post: User 27258
  Pinebook Pro malfunctioned hardware samtux 10 4,484 12-27-2022, 03:31 PM
Last Post: samtux
  Touchpad Issues - August 2022 Run SteveCaruso 5 3,013 12-14-2022, 11:00 PM
Last Post: doug
  PineBook Pro revision 2.2: Wishlist for the hardware issue fixes dsimic 115 137,183 11-30-2022, 04:28 PM
Question PINEBOOK Pro USB-C Docking Deck issues pawzy 3 4,955 06-19-2022, 09:47 AM
Last Post: Rosbeefandino
  Hardware shortcomings commiecam 14 9,184 01-30-2022, 09:04 AM
Last Post: moonwalkers
  Pinebook pro Hardware failure: how should I diagnose it? alxndr.psclt 5 4,732 09-08-2021, 09:03 PM
  Pinebook Pro Boot Issues - Booting needs multiple attempts mtndew 13 17,617 10-04-2020, 08:55 AM
