Bionic image boot from SD
(01-16-2020, 02:45 AM)mamboman777 Wrote: I flashed Bionic onto the eMMC and now SD boot is no longer working.  I think the uboot is the issue, but I do not know how to go about fixing it.  Ideas?
Hey assuming you're folowing this guide: https://forum.pine64.org/showthread.php?tid=8119
Sounds like you needed step 6..
6. Now you have Ubuntu installed on eMMC and you can also boot from SD card, but only the same operating system. If we need also to boot other operating systems, we need to apply uboot fix. So download all the files from here https://github.com/mrfixit2001/updates_r...filesystem and run the mrfixit_update.sh script while running from eMMC. From now on you should be able to boot also other OS from SD like before.
Download those files and run the script and then it starts working.e
Bionic image boot from SD - by mamboman777 - 01-16-2020, 02:45 AM
RE: Bionic image boot from SD - by pete - 01-16-2020, 06:34 AM
RE: Bionic image boot from SD - by mamboman777 - 01-16-2020, 07:08 AM
RE: Bionic image boot from SD - by tophneal - 01-16-2020, 07:44 AM
RE: Bionic image boot from SD - by mamboman777 - 01-16-2020, 08:09 AM
RE: Bionic image boot from SD - by tophneal - 01-16-2020, 08:14 AM
RE: Bionic image boot from SD - by mamboman777 - 01-16-2020, 08:19 AM
RE: Bionic image boot from SD - by tophneal - 01-16-2020, 08:25 AM
RE: Bionic image boot from SD - by mamboman777 - 01-16-2020, 09:25 AM
RE: Bionic image boot from SD - by pete - 01-17-2020, 06:39 AM
  uboot wont boot to SD card after upgrade jbradley419 7 916 01-19-2024, 02:29 PM
  Video Flashing/adjusting on boot and reboot jbradley419 0 310 01-16-2024, 09:17 AM
Last Post: jbradley419
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 2,305 12-15-2023, 02:11 PM
  PBP won't boot after trying to reinstall Manjaro ARM soupgirl 3 727 12-13-2023, 08:17 PM
Last Post: trillobite
  Various freezes during boot & while running several Linux distros - hardware error? donuts 1 617 11-22-2023, 11:47 AM
Last Post: fxc
  Cannot boot to Kali SD card after uboot upgrade jbradley419 4 1,234 09-19-2023, 08:48 AM
Last Post: dachalife
  Does latest Tow-Boot install/work correctly for everyone? tophneal 4 1,944 08-03-2023, 03:30 PM
  Boot into NVME drive, no wifi, sound, buttons... PaulQ 0 818 07-13-2023, 01:50 PM
Last Post: PaulQ
  New Pinebook pro won’t boot Generaltuxenburg 4 1,985 06-14-2023, 07:20 AM
Tongue Yet another Pinebook Pro won't boot thread pinemouth 4 2,476 05-20-2023, 01:02 AM
Last Post: jackwilson
