Unable to boot: blinking red light
What's installed on your eMMC? If this occurred after installing Manjaro to the eMMC, then you probably need to wipe it and reinstall. Easiest way to make that possible without the adapter or UART cable (at least in my opinion) would be to:
-Determine a working surface where you can take the bottom casing of PBP off.
-Place a soft material down by the edge of your surface, and lay the PBP keyboard tray onto it. The screen should be hanging off the edge, upside down. (I suggest doing this so that you don't have to worry about damaging the case by opening the lid w/o the bottom casing.)
-Remove the bottom casing (be sure to read the wiki for various precautions beforehand.)
-Flip the eMMC switch to OFF.
-Put the PBP on its side, so you can access the Power key.
-Insert your Manjaro installer SD card.
-Turn on the PBP.
-Once you see the PBP booting off of the SD, flip the eMMC switch back on.
-Use your Manjaro SD to either wipe the eMMC and shutdown (so you can put the PBP back together, boot back into the SD and try installing again.)
Unable to boot: blinking red light - by houki - 01-15-2020, 12:16 PM
RE: Unable to boot: blinking red light - by tophneal - 01-15-2020, 12:17 PM
RE: Unable to boot: blinking red light - by houki - 01-15-2020, 02:26 PM
RE: Unable to boot: blinking red light - by houki - 01-18-2020, 04:45 AM
RE: Unable to boot: blinking red light - by wdt - 02-11-2020, 01:05 AM
Sad What to can't boot from TF card, EMMC system broken - any advice?do guys? qingss0 1 722 12-18-2025, 01:05 AM
Last Post: qingss0
  Bonk to boot biketool 2 1,230 10-21-2025, 09:08 AM
  3 days in, slow/stuck or no boot. lgmpbp2 34 24,470 06-11-2025, 08:53 AM
Last Post: lgmpbp2
  upgrading u-boot--what version? where to get it? bsammon 14 15,427 04-03-2025, 07:47 AM
Last Post: Tazdevl
Tongue Yet another Pinebook Pro won't boot thread pinemouth 5 10,997 12-27-2024, 11:38 AM
Last Post: akash3995
  broken tow-boot hashkeeper 1 3,709 12-25-2024, 10:12 PM
Last Post: jessipinkman
  Unable to use umlaut key combos ili 4 4,641 12-02-2024, 03:56 PM
  Cant boot into an OS trashtendenz 3 4,794 10-23-2024, 03:49 AM
Last Post: chaylengordon
  Unable to boot? YossiS 4 3,359 09-04-2024, 10:35 AM
  uboot wont boot to SD card after upgrade jbradley419 7 7,529 01-19-2024, 02:29 PM
