Renaming home folder
(01-15-2020, 09:06 AM)Arwen Wrote: Well, it looks like the rename of the group and home directory did not go through.
Using "root" from a text console, you can use this to try and fix it.
groupmod -n adam rock
tail /etc/group
ls -l /home
usermod -d adam -m adam
tail /etc/passwd
ls -la /home/adam
That should do it. I've included some verification steps to help.
But, I guarentee nothing :-).
This seemed to partly work, but the final command gave me the message:
ls: cannot access '/home/adam': No such file or directory
And I'm now unable to login to user adam from the login screen. It just keeps taking me back to the login screen unless I log in as root.
Time to just create a new user?
OK, after doing:
-d /home/adam -m adam
I was able to once again login as adam from the GUI login screen.
Once in the account, a pop-up indicated:
Configured directory for incoming files does not exist.
Please make sure that directory "/home/rock" exists or configure it with blueman-services
I ran blueman-services to attempt to change the incoming folder, but clicking on the dropdown is unresponsive. Hovering the cursor over the drop down shows the message: "Applet's transfer service plugin is disabled".
Terminal gave the following readout:
adam@Debian-Desktop:~$ blueman-services
blueman-services version 2.0.4 starting
_________
load_plugins (/usr/bin/blueman-services:91)
['Network', 'Transfer']
_________
set_page (/usr/bin/blueman-services:138)
Set page Transfer
Gtk-Message: GtkDialog mapped without a transient parent. This is discouraged.
(blueman-services:1259): Gtk-WARNING **: Failed to fetch network locations: Timeout was reached
Am I screwed? Should I create a new user and delete user adam? If so, uh, how do I do that?
Renaming home folder - by inkslinger - 01-14-2020, 05:19 PM
RE: Renaming home folder - by evilbunny - 01-14-2020, 06:50 PM
RE: Renaming home folder - by inkslinger - 01-14-2020, 08:17 PM
RE: Renaming home folder - by Arwen - 01-14-2020, 09:22 PM
RE: Renaming home folder - by inkslinger - 01-14-2020, 09:37 PM
RE: Renaming home folder - by ElektromAn - 01-15-2020, 10:27 AM
RE: Renaming home folder - by inkslinger - 01-15-2020, 10:41 AM
RE: Renaming home folder - by Arwen - 01-15-2020, 09:06 AM
RE: Renaming home folder - by inkslinger - 01-15-2020, 01:10 PM
RE: Renaming home folder - by ElektromAn - 01-15-2020, 11:22 AM
RE: Renaming home folder - by inkslinger - 01-15-2020, 03:09 PM
RE: Renaming home folder - by appdev46 - 01-15-2020, 03:50 PM
RE: Renaming home folder - by Jeremiah Cornelius - 01-15-2020, 06:15 PM
RE: Renaming home folder - by appdev46 - 01-15-2020, 08:16 PM
RE: Renaming home folder - by Jeremiah Cornelius - 01-15-2020, 09:14 PM
RE: Renaming home folder - by appdev46 - 01-16-2020, 07:02 PM
RE: Renaming home folder - by Arwen - 01-17-2020, 06:37 AM
RE: Renaming home folder - by appdev46 - 01-18-2020, 11:09 AM
RE: Renaming home folder - by appdev46 - 01-22-2020, 04:21 AM
RE: Renaming home folder - by inkslinger - 01-22-2020, 10:09 AM
RE: Renaming home folder - by mainer - 01-22-2020, 10:40 AM
RE: Renaming home folder - by appdev46 - 01-22-2020, 02:16 PM
RE: Renaming home folder - by Arwen - 01-22-2020, 03:45 PM
  Network shared folder discovery (smb4k) solostian 10 8,790 12-06-2021, 07:27 AM
Last Post: solostian
  Cant boot into home-rolled Arch Linux image craftkiller 4 4,731 02-25-2020, 12:58 PM
Last Post: craftkiller
