In-Circuit Programming of SPI NOR Flash
(04-18-2020, 10:43 AM)tsys Wrote: Hi,
I do not think there is any reason to use external hardware for flashing. The SPI flash can simply be written from within the OS (or even u-boot).
Thanks for the tip @tsys  =)
I am still learning embedded computing and am a u-boot novice. But I have learned the minimum required to get started. So far I have  a tiny image I have created which uses the master u-boot sources (includes your work). When burned to micro SD card, u-boot loads as expected and I am able to probe the spi flash successfully.
Looking forward to building and flashing u-boot to spi next. Have to do a little more homework first.
RE: In-Circuit Programming of SPI NOR Flash ROM - by hmuller - 09-13-2020, 01:20 PM
  Extracting a copy of SPI NOR flash contents using micro SD card and u-boot hmuller 0 5,318 09-21-2020, 11:24 AM
Last Post: hmuller
  Program SPI NOR Flash on Pinebook Pro with u-boot on micro SD Card hmuller 0 6,552 09-21-2020, 10:02 AM
Last Post: hmuller
Exclamation Flash dhivael's SPI uboot (risky) clover 51 90,680 06-20-2020, 03:24 PM
Last Post: craftkiller
  Widevine-flash on Chromium-SD Card mamboman777 3 10,516 01-20-2020, 04:00 PM
