Disable auto power on?
Is it possible to disable the feature of the Pinebook booting up when plugged into power? When I have my Pinebook 11" 1080P plugged into an intermittent power supply, it will start up when the power goes on, then stay running and discharging when the power is off. When it is plugged in and running, the battery doesn't charge, so I need to be able to keep it off so it will charge. The auto power on interferes with that. For example, I might leave it plugged in and powered off overnight to charge, only to find in the morning that it discharged almost to zero because the power went off and on, and maybe off again. Trying to charge the computer from a vehicle's power outlet also becomes impractical, because the vehicle's power goes off and on.
There is also a thread for this issue in the Pinebook Pro: https://forum.pine64.org/showthread.php?tid=8211
Disable auto power on? - by cel - 12-22-2019, 08:41 AM
  pinebook 1080p power/barrel connector/cable cel 0 1,209 08-03-2023, 11:43 AM
Last Post: cel
  Add separate power button? maddmike 2 4,547 12-17-2018, 04:35 PM
Last Post: maddmike
  Power supply clarification maldus 5 7,827 12-17-2018, 03:55 AM
Last Post: maldus
  Power LED / Charging LED Question d97 4 6,667 11-21-2018, 10:26 AM
Last Post: Noxmiles
  UK Power Adapter? dejan 5 8,560 12-06-2017, 04:44 PM
Last Post: DigitalStefan
  Internal power connector problem stealthbanana 1 3,885 09-19-2017, 10:45 AM
Last Post: MarkHaysHarris777
  noise random green pixel when plugged power supply only (solved. see edit.) BatteryDie 5 8,650 09-06-2017, 04:17 PM
Last Post: BatteryDie
Question Power Related Problem Questions p3p1 1 3,283 08-29-2017, 06:06 PM
  Wanted: Better power adapter for Pinebook. flingtoad 4 8,048 08-21-2017, 10:09 PM
Last Post: Siliconserf
Thumbs Down Power Supply Design Flaw Siliconserf 11 16,123 08-15-2017, 12:26 PM
