Slide out keyboard discussion thread
(12-12-2019, 07:39 AM)murak Wrote: The design for the official Pinephone keyboard is set to resemble that of Psion which will make room for a relatively large keyboard. The typing experience will most likely be excellent considering the size. I am very thankful that Pine64 is planning a keyboard for the Pinephone!
That said, some users was maybe picturing a slide out keyboard similar to Nokia N900 or early Droid phones which would make typing on the go with your thumbs more comfortable. One other aspect is the ability to see and use the screen and notification led while the keyboard is tucked away.
So, the question is if there is demand for a slide out keyboard (and if someone can make one)? In this thread we can discuss how a slide out keyboard could be designed and also get a feel for the demand.
I will start with a picture of a cheap BT keyboard for a iPhone, which resembles what I personally had in mind.
[Image: 31xanPKB6DL.jpg]
Thoughts:
-If there is no hole in the keyboard for the camera, then you would have to slide out the keyboard every time you wanted to take a picture.
-The weight of the phone is far greater than that of the keyboard. This could make for an unpleasant typing experience and would also put extra stress on the slide out mechanism. Adding for example a extra battery in the keyboard part would counter this, but would ad to total thickness.
-The keyboard area would be much smaller than that of a Psion design, so one would have to really think through what keys to include. A quick look at the Fxtec Pro 1 can help with desiding since they have put a lot of thought in to the matter already. A software bar at the bottom of the screen is also possible but would take time to develop.
-Is dedicated gaming buttons something to consider? Look at GPD Win and Dragonbox Pyra for inspiration.
-The N900 had a kickstand that was excellent when viewing videos and the N7 and Fxtec Pro 1 tilts the screen when using the keyboard. I have seen keyboards similar to the one in the picture above that has a hinge, but I suspect it might make the design less sturdy and there is also the problem with weight distribution.
Please share your thought and keep it friendly and constructive Smile
I'm very excited about the Pinephone and the possibility of having a physical keyboard.  I, for one, would like a hole for the camera.
However, with the problems and complexity of fitting a sliding keyboard to the back of the phone, has anybody brought up the possibility of creating a "Pinephone2" with a Blackberry style keyboard built into the phone?
Slide out keyboard discussion thread - by murak - 12-12-2019, 07:39 AM
RE: Slide out keyboard discussion thread - by r@di0guy - 12-18-2019, 02:14 PM
  keyboard case charging but not typing new2pinephone 18 5,959 02-19-2024, 07:30 AM
Last Post: theResonant
  Keyboard doesn't charge my phone no matter what, so can I charge my phone directly ragreenburg 3 10,245 01-14-2024, 03:34 PM
Last Post: acid andy
  I've added an I2C connector to the PP keyboard eugenr 0 452 11-26-2023, 07:24 AM
Last Post: eugenr
  Update the PinePhone keyboard driver to support missing characters? Peter Gamma 8 8,265 10-22-2023, 08:43 PM
Last Post: Peter Gamma
  key repeat with pinephone keyboard rotwang 0 468 10-22-2023, 03:39 PM
Last Post: rotwang
Exclamation USB mouse isn't working when a PP keyboard is attached? mikeb 3 1,280 10-21-2023, 08:21 PM
  Pinephone with mini keyboard, trackpad and large power bank? Peter Gamma 0 538 10-21-2023, 07:50 AM
  Which mini keyboard and mouse to choose for the PP? Peter Gamma 0 639 10-21-2023, 02:55 AM
  Use the Linux Console with the PinePhone Keyboard mburns 2 1,053 10-20-2023, 04:11 PM
Last Post: mburns
  How to disassemble Keyboard top and replace cables? elof 2 861 10-11-2023, 09:03 AM
Last Post: elof
