Cannot boot up after hours off
(12-10-2019, 05:31 PM)Jeremiah Cornelius Wrote: The symptoms are not conclusively indicating an issue with hardware. I'd try to see if this is reproducible with a different OS distribution booting from alternative media.
I have experience with alternative machinery and different OS's that presented similar problems - such as Macbooks running Debian, and NetBSD on SGI hardware. Angry
If the native OS behaved, I could rule out the machine itself.
If you are able to reproduce this with the PinebookPro Debian on SD, then you can zero in on this being a defective unit.
— Jeremiah
That's a fair point. Here's what I did today:
1, Booted into SD-card-located debian build
1, Downloaded the official debian build
2, Unpacked it (unxz) and wrote it onto eMMC (dd if=<debian-image> of=/dev/mmcblk1 bs=4M status=progress), overriding the existing fresh Manjaro install
4, Booted with eMMC (no SD card inserted) into the debian build.
5, ran the upgrade script by mrfixit
6, Rebooted after the script finished and outputted that I should reboot
==> first issue: laptop powered down, but did not boot back up (but maybe this is a post-update symptom?)
7, long-press power button (5~10 sec) > short-press (3 sec) > booted up (long press only because the power led did not turn on in 3 sec as expected)
8, new restart test
==> failed the same way again
9, long-press power button (5~10 sec) > short-press (3 sec) > booted up
10, another restart test
==> failed again
11, long-press power button (5~10 sec) > short-press (3 sec) > booted up
12, Two shutdown -> boot tests; both OK
13, In shutdown state, waited 1 hour
14, Press button to boot up
==> failed
14, long-press power button > short-press > booted up
What do you think? Is this a sufficient test to start doubting the hardware?
Do we have any specific support contacts that I can reach out to? (anybody aware?)
Cannot boot up after hours off - by tsago - 12-10-2019, 05:13 PM
RE: Cannot boot up after hours off - by tsago - 12-11-2019, 07:24 AM
RE: Cannot boot up after hours off - by pjsf - 12-11-2019, 04:42 PM
RE: Cannot boot up after hours off - by tsago - 12-12-2019, 05:35 AM
  uboot wont boot to SD card after upgrade jbradley419 7 998 01-19-2024, 02:29 PM
  Video Flashing/adjusting on boot and reboot jbradley419 0 333 01-16-2024, 09:17 AM
Last Post: jbradley419
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 2,397 12-15-2023, 02:11 PM
  PBP won't boot after trying to reinstall Manjaro ARM soupgirl 3 781 12-13-2023, 08:17 PM
Last Post: trillobite
  Various freezes during boot & while running several Linux distros - hardware error? donuts 1 647 11-22-2023, 11:47 AM
Last Post: fxc
  Cannot boot to Kali SD card after uboot upgrade jbradley419 4 1,276 09-19-2023, 08:48 AM
Last Post: dachalife
  Does latest Tow-Boot install/work correctly for everyone? tophneal 4 1,999 08-03-2023, 03:30 PM
  Boot into NVME drive, no wifi, sound, buttons... PaulQ 0 830 07-13-2023, 01:50 PM
Last Post: PaulQ
  New Pinebook pro won’t boot Generaltuxenburg 4 2,039 06-14-2023, 07:20 AM
Tongue Yet another Pinebook Pro won't boot thread pinemouth 4 2,533 05-20-2023, 01:02 AM
Last Post: jackwilson
