Does the Pinebook Pro support chromium developer mode?
I think tllim is correct, but from what I've noticed reading guides and mucking about within my install, several features of the Developer Mode are still available within the install. Many seem to even be available within the base image. For example, Crouton requires use of Developer Mode, but I've gotten it to mostly work (no X/xiwi) without having to do anything special. ayufan would be the one to know, though. It could be like some Chromebooks, and require use of the Recovery button inside the case.
RE: Does the Pinebook Pro support chromium developer mode? - by tophneal - 12-04-2019, 09:41 AM
  FydeOS for You - Pinebook Pro also1412 52 139,513 12-19-2022, 07:42 PM
Last Post: wangyukunshan
  Which OS can I actually run a 1080p pinebook non-pro? Scott104 1 6,461 10-09-2021, 02:47 PM
Last Post: TRS-80
  Black screen on both FydeOS as Chromium from github QuinTeknoLife 0 6,888 04-15-2021, 11:44 AM
Last Post: QuinTeknoLife
  Looking to commission a new Chromium build (COMMUNITY BOUNTY) tophneal 86 168,270 11-06-2020, 09:25 AM
  CrOS boot from sd, now pinebook doesn't boot anymore qdoy55d9wkn8zw 7 18,002 06-22-2020, 06:23 AM
  Chromium OS 78? obyknovenius 2 8,924 02-04-2020, 02:11 PM
Last Post: brent.thierens
  Possible to use different uboot with Chromium? tophneal 1 6,322 11-04-2019, 08:38 AM
