USB3 won't power 2,5" external HDD
(11-20-2019, 06:29 PM)hmuller Wrote: I'm using a Seagate Backup Plus 2TB on the PBP's USB 3.0 port. Haven't experienced any issues with it, so can recommend it for use.
In my case it's a seagate backup plus portable 5TB, seems to draw more amps...
(11-20-2019, 07:42 PM)neilman Wrote: I have just tested a 5TB Seagate Backup Plus drive with my PineBook Pro
Using the stock, updated, out-of-box software...
USB 3 socket : Works perfectly, plays videos with VLC fine, ejects safely.
USB 2 socket : Powers and clicks a lot but does not appear to function properly - no device shows up.
USB C socket : Appeared to power up initially but after a few seconds it just powered off and died.
Retrying in the USB 3 socket worked fine again and was able to eject safely.
Running off a power bank with a power meter connected shows short high starting current of 670mA dropping to a quiescent idling current of 240mA.
(Since my power meter only refreshes its display a few times a second the peak current might be much higher).
I have a Seagate Backup Plus Portable 5TB and a silicon power armor with the same HDD. None work in USB3. The silicon power works fine in USB-C. The seagate will spin up but won't mount (won't even be shown in the device notifier (I'm running Kubuntu 19.10)). Both work fine on other systems. I guess I'll order one of those USB measurement thingies, to see what's really going on the with the voltage and currrent.
USB3 won't power 2,5" external HDD - by Tiedemate - 11-20-2019, 10:24 AM
RE: USB3 won't power 2,5" external HDD - by Tiedemate - 11-21-2019, 03:31 AM
RE: USB3 won't power 2,5" external HDD - by Arwen - 11-20-2019, 07:12 PM
  Pinebook Pro on Debian 12 Power Issue u974615 1 344 03-13-2024, 10:46 AM
Last Post: u974615
  Increasing the maximum power draw dsimic 15 19,676 11-21-2022, 03:36 AM
Last Post: bircoph
  Alternative Power supply options gallomimia 13 17,966 11-13-2022, 06:10 PM
Last Post: pineymousepad
  PBP booting but stops at flashing power led jonasd 13 5,515 09-26-2022, 12:17 AM
Last Post: jonasd
  Blinking red light for charger, no power-on bifo 11 13,835 11-30-2021, 01:37 PM
  power on PBP if your keyboard is dead? stozi 0 1,340 11-29-2021, 01:55 PM
Last Post: stozi
  Motherboard malfunction - a possible warning about power supplies mjc 8 7,131 07-28-2021, 01:04 PM
Last Post: mjc
Question External Monitor not Working sciolus 5 5,089 05-05-2021, 02:05 AM
Last Post: aurora.borealis
Question UK Power Supply User 11436 11 17,508 02-09-2021, 12:30 PM
Last Post: dieselnutjob
  Pinebook Pro Dock Power Requirements calinb 9 12,193 12-16-2020, 09:24 AM
Last Post: dsimic
