Rockpro64 PCI-Express Issue.
(04-22-2020, 08:56 AM)kuleszdl Wrote: @t4_4t @pgwipeout Thank you for sharing these interesting findings!
My board is v2.1 2018-07-02 and it does NOT have the mentioned capacitors. I am not sure about the jumpers you mentioned but I don't see any wires there. Would it make sense to add them?
Here's a picture of my unit, I will try to supply a better picture later:
Also, could you please describe the performance improvement you gained? Currently, I am getting only 560-580 MB/s in `hdparm --direct -t` test with a Samsung 970 Evo that is supposed to be much faster as well as a kernel panic when I insert a Dualport NIC (both cards are PCIe x4).
Unfortunately I didn't have a card that hit the upper bandwidth until after I modified it.
What I did notice is under heavy data load my network card would occasionally fault and require a board reset to recover completely.
The kernel also pogos less while enumerating the card, and pcie init completes about a second faster.
Can't guarantee if the jumpers will help you, since I also had to remove the resistors that are already gone from your board.
I did a lot of research into pcie design before deciding to go all the way, because removing components is easy, putting components on is a lot harder.
By the way, what is the exact kernel version you are using? <uname -a>
Rockpro64 PCI-Express Issue. - by t4_4t - 11-18-2019, 09:22 PM
RE: Rockpro64 PCI-Express Issue. - by maya.b - 11-19-2019, 08:02 AM
RE: Rockpro64 PCI-Express Issue. - by pgwipeout - 04-17-2020, 05:46 AM
RE: Rockpro64 PCI-Express Issue. - by pgwipeout - 04-17-2020, 12:21 PM
RE: Rockpro64 PCI-Express Issue. - by t4_4t - 11-19-2019, 07:34 PM
RE: Rockpro64 PCI-Express Issue. - by dukla2000 - 11-20-2019, 04:24 AM
RE: Rockpro64 PCI-Express Issue. - by t4_4t - 11-20-2019, 07:51 AM
RE: Rockpro64 PCI-Express Issue. - by t4_4t - 11-20-2019, 09:44 AM
RE: Rockpro64 PCI-Express Issue. - by dukla2000 - 11-21-2019, 03:46 AM
RE: Rockpro64 PCI-Express Issue. - by fysa - 02-19-2020, 09:06 AM
RE: Rockpro64 PCI-Express Issue. - by kuleszdl - 04-22-2020, 08:56 AM
RE: Rockpro64 PCI-Express Issue. - by pgwipeout - 04-22-2020, 09:08 AM
RE: Rockpro64 PCI-Express Issue. - by pgwipeout - 04-23-2020, 04:55 AM
RE: Rockpro64 PCI-Express Issue. - by dsimic - 12-17-2020, 10:01 AM
RE: Rockpro64 PCI-Express Issue. - by tllim - 12-23-2020, 05:18 PM
RE: Rockpro64 PCI-Express Issue. - by dsimic - 12-27-2020, 05:11 PM
RE: Rockpro64 PCI-Express Issue. - by t4_4t - 04-23-2020, 05:54 AM
RE: Rockpro64 PCI-Express Issue. - by pgwipeout - 04-23-2020, 07:33 AM
RE: Rockpro64 PCI-Express Issue. - by kuleszdl - 04-23-2020, 07:56 AM
RE: Rockpro64 PCI-Express Issue. - by pgwipeout - 04-23-2020, 08:02 AM
RE: Rockpro64 PCI-Express Issue. - by kuleszdl - 04-23-2020, 08:38 AM
RE: Rockpro64 PCI-Express Issue. - by pgwipeout - 04-23-2020, 10:28 AM
RE: Rockpro64 PCI-Express Issue. - by kuleszdl - 04-23-2020, 11:22 AM
RE: Rockpro64 PCI-Express Issue. - by pgwipeout - 04-23-2020, 12:06 PM
RE: Rockpro64 PCI-Express Issue. - by kuleszdl - 04-23-2020, 01:17 PM
RE: Rockpro64 PCI-Express Issue. - by pgwipeout - 04-23-2020, 02:27 PM
RE: Rockpro64 PCI-Express Issue. - by kuleszdl - 04-23-2020, 04:52 PM
RE: Rockpro64 PCI-Express Issue. - by pgwipeout - 04-24-2020, 11:27 AM
  ROCKPro64 Battery Power Supply hoarfrosty 12 2,209 04-01-2024, 10:24 PM
Last Post: nano2
  Powering on the Rockpro64 JPT223 1 943 09-24-2023, 12:23 PM
Last Post: hoarfrosty
  ROCKPro64 with 16 ports SATA controller ZeblodS 19 26,173 12-18-2022, 06:25 PM
Last Post: heyghoge
  Using RPI hat on RockPro64? misterc 0 874 12-16-2022, 02:05 PM
Last Post: misterc
  GPIO on the RockPro64 - all pins high? colinmarc 2 1,687 11-18-2022, 10:20 AM
Last Post: colinmarc
  ROCKPro64 DOA ajtravis 8 6,812 11-08-2022, 03:40 AM
Last Post: ajtravis
  RockPro64 not booting up mvicha@gmail.com 0 1,178 09-19-2022, 07:35 AM
Last Post: mvicha@gmail.com
  GPIO Expander HAT for ROCKPro64 and Quartz64 CounterPillow 7 5,509 07-18-2022, 10:05 PM
Last Post: zer0sig
  RockPro64 premium aluminium casing justwantin 2 2,217 05-27-2022, 06:51 PM
Last Post: justwantin
  charging 3 rockpro64 from single source rpt312 1 1,778 05-16-2022, 02:34 AM
Last Post: dukla2000
