Deepin Desktop on PBP
Well what I did is went to this website
https://www.archlinux.org/groups/x86_64/deepin/
Here you have all the packages by name. Then use svn to check out the project tree of arch linux:
https://wiki.archlinux.org/index.php/Arc..._using_SVN
Then you have a bunch of folders, if you go into those folder, you should be able to just run makepkg -s -i -A
A to ignore architecture (they are made for x86)
i to install it after build
s to sync dependencies
If you need more help, let me know Smile
PS sometimes you will have circular dependencies, just remove the dependency in the PKGBUILD, build it, build the others, restore the original PKGBUILD and build it again. Then you should be fine.
Hope this helps!
Deepin Desktop on PBP - by brent.thierens - 11-08-2019, 06:12 PM
RE: Deepin Desktop on PBP - by derzahl - 12-10-2019, 01:15 PM
RE: Deepin Desktop on PBP - by brent.thierens - 12-10-2019, 01:59 PM
RE: Deepin Desktop on PBP - by derzahl - 12-10-2019, 05:00 PM
RE: Deepin Desktop on PBP - by derzahl - 12-10-2019, 06:34 PM
RE: Deepin Desktop on PBP - by brent.thierens - 12-11-2019, 01:42 AM
RE: Deepin Desktop on PBP - by bastafari - 09-12-2020, 08:51 PM
RE: Deepin Desktop on PBP - by brent.thierens - 09-13-2020, 01:40 AM
RE: Deepin Desktop on PBP - by bastafari - 09-14-2020, 07:02 PM
RE: Deepin Desktop on PBP - by brent.thierens - 09-17-2020, 01:19 PM
RE: Deepin Desktop on PBP - by bastafari - 09-18-2020, 08:03 AM
RE: Deepin Desktop on PBP - by Upokupo - 10-29-2020, 10:02 AM
  Install deepin OS on pinebook pro wangyukunshan 4 1,676 08-07-2023, 01:12 PM
Last Post: myself600
Rainbow How to prevent the screen from dimming (no X/wm/desktop)? cowsay 0 563 02-16-2023, 10:58 AM
Last Post: cowsay
  Install the DDE desktop environment wangyukunshan 0 1,351 12-23-2021, 06:51 PM
Last Post: wangyukunshan
  Desktop environment of Ubuntukylin 20.04 wangyukunshan 3 3,266 10-26-2021, 08:07 PM
  No wifi icon on desktop and no connectivity motezart 0 2,014 11-16-2020, 12:52 PM
Last Post: motezart
  Signal Desktop Builds for Manjaro aarch64 ninefathom 25 31,328 10-23-2020, 02:19 PM
Last Post: llsf
  Virtual Desktop Issues (Manjaro KDE) davemaps 1 3,274 08-31-2020, 07:28 PM
Last Post: brad2723
  0.9.14 Release: Ubuntu 18.04 with Mate & LXDE Desktop Luke 86 98,561 04-09-2020, 09:33 AM
Last Post: mmt
Lightbulb Has anyone tried to install Gnome 3 desktop? User 11436 26 31,133 01-02-2020, 02:03 AM
Last Post: bcnaz
  Debian Desktop off SD? zaius 20 21,938 11-23-2019, 04:03 PM
Last Post: Mrfixit2001
