No sound on PBP default installation
(11-09-2019, 02:10 AM)bcnaz Wrote:
(11-08-2019, 08:13 PM)brucec1999 Wrote:
(11-08-2019, 07:03 AM)ivek Wrote: Hi,
I just received the PBP with preinstalled Debian + Mate. everything is more or less fine, except that the sound doesn't work at all:
 - neither on speakers, nor on headphones
 - in Alsamixer no setting helped me, when trying to set output to default, the Alsamixer aborts and I can't rerun it
 - I tried checking sound from "control panel", I think there is no connection to Pulseaudio (but Pulseaudio is installed)
 - when I play a song (no sound ofcourse), one setting in volume control says that there is no app playing the sounds, although it's playing.
I haven't tried to update anything, I don't know the commands.
I don't know if I need maybe to set that UART switch if set to off, but I need to open the laptop for that. (as in thread https://forum.pine64.org/showthread.php?tid=8231)
I haven't tried it on HDMI, I don't see that port, only UCB-C, if it is meant for HDMI, I have no adapter to try..
I am pretty much a noob in Linux, so any help with an elaborated answer (links to explanations like "how to install or try out a new OS") would be appreciated  Smile
Hi ivek,
I received my PBP just yesterday, and also had no sound. Found that "output volume" was set to Mute (under Control Center - Sound Preferences). All good once unchecked. Note: the "test speakers" under hardware does not work.
Apologies if this was really obvious and you have already checked this setting.
Cheers Bruce.
I had the same problem,  there is another thread on this same subject,  Deebeez had a quick & easy fix.....
rather than repeat it I suggest looking at that other thread...
AND  check your audio with real sound like YouTube or something....  The 'Test speaker'  does not seem to work on this OS.
Thanks four your help guys, still no luck
@bruce, All settings in that sound are grayed out, maybe that's a clue Smile
@bcnaz, We already tried turning on everything in Alsamixer, the sound output is set to the only device that could play... if I set it to "default", the Alsamixer aborts and can't be started again...
If nothing helps, I will buy a MicroSD card and try another OS
No sound on PBP default installation - by ivek - 11-08-2019, 07:03 AM
RE: No sound on PBP default installation - by ivek - 11-09-2019, 06:28 AM
  Pinebook pro won't boot after bootloader installation jwensouls 4 2,360 08-21-2024, 04:17 AM
  Fedora 37 installation gswatkins 16 12,120 03-16-2024, 03:09 PM
Last Post: michel_luc
  Nethunter default password failed lamlarryyyy 0 1,527 11-23-2023, 02:48 AM
Last Post: lamlarryyyy
  Sound on Armbian Bram 1 2,050 04-01-2023, 03:16 PM
Last Post: TRS-80
  HOW TO create a installation USB with ... (see below) Ice-O-Star 1 2,341 01-06-2023, 01:02 PM
Last Post: DrYak
  My installation guide starting from messed up eMMC Besouro 0 1,574 12-19-2022, 01:01 PM
Last Post: Besouro
  Hibernation and Speaker Sound Issues, First Month of PBP kebab 7 5,486 11-02-2022, 02:33 PM
Last Post: kebab
  Loud distorted speaker sound when connecting to power supply myself600 2 2,184 09-21-2022, 12:11 PM
Last Post: myself600
  reset sound after suspend to memory (deep sleep) Der Geist der Maschine 16 23,067 10-18-2021, 07:31 PM
Last Post: Syonyk
  Sound stuttering on Manjaro gnome after latest kernel upgrade? pjsf 0 2,449 07-13-2021, 10:37 PM
Last Post: pjsf
