Power measurements
#20
(11-21-2019, 09:42 PM)pfeerick Wrote:
(11-21-2019, 03:07 PM)Der Geist der Maschine Wrote: What I wrote is not what I meant ;-/ I meant "capacity". "current_now" might be also worth monitoring.
Any of those three would give you some idea of what's happening... `voltage_now` constantly dropping would tell you either the unit isn't plugged into external power, or the power supply can't keep up with the load. `current-now` would be the best of the three to monitor, as it will respond a lot faster than `capacity`, and will go positive/negative depending on if the unit is charging or discharging.
Depending on what how the paths have changed (if any), this script I used for the original pinebook with A64 processor might be handy to use now... logs to screen and file for later analysis. Wink
https://github.com/pfeerick/pine64-scrip...yLogger.sh
Earlier this day, I measured all three with a 1 liner Tongue
make -j5.
Copy/paste removed the tabs.
time     capacity current voltage
18:58:13 100 0 4357000
18:58:14 100 0 4357000
18:58:15 100 0 4357000
18:58:16 100 0 4357000
19:31:55 100 0 4203000
19:31:56 100 0 4203000
19:31:57 100 0 4203000
19:31:58  91 0 3971000
19:31:59  91 0 3971000
19:32:00  91 0 3971000
19:32:01  91 0 3971000
19:32:02  91 0 4202000
Capacity significantly went down within a second. I assume during that second, there was a spike in current as well.
Power measurements - by jpakkane - 11-07-2019, 03:52 PM
RE: Power measurements - by VoxUnius - 11-10-2019, 10:42 PM
RE: Power measurements - by aaditya - 11-13-2019, 11:12 AM
RE: Power measurements - by VoxUnius - 11-13-2019, 08:43 PM
RE: Power measurements - by VoxUnius - 11-11-2019, 02:46 AM
RE: Power measurements - by hmuller - 11-11-2019, 05:08 AM
RE: Power measurements - by Axevy - 11-11-2019, 08:21 AM
RE: Power measurements - by danielt - 11-12-2019, 03:40 AM
RE: Power measurements - by MrTester - 11-13-2019, 09:09 PM
RE: Power measurements - by VoxUnius - 11-13-2019, 09:55 PM
RE: Power measurements - by aaditya - 11-21-2019, 12:13 AM
RE: Power measurements - by VoxUnius - 11-21-2019, 01:55 AM
RE: Power measurements - by pfeerick - 11-21-2019, 05:11 AM
RE: Power measurements - by hmuller - 11-21-2019, 05:58 AM
RE: Power measurements - by VoxUnius - 11-21-2019, 06:43 AM
RE: Power measurements - by hmuller - 11-21-2019, 02:16 PM
RE: Power measurements - by pfeerick - 11-21-2019, 09:42 PM
RE: Power measurements - by Der Geist der Maschine - 11-21-2019, 10:00 PM
RE: Power measurements - by pfeerick - 11-22-2019, 03:31 AM
RE: Power measurements - by VoxUnius - 11-22-2019, 05:06 AM
RE: Power measurements - by VoxUnius - 11-21-2019, 11:45 PM
RE: Power measurements - by hmuller - 11-22-2019, 06:18 AM
RE: Power measurements - by pfeerick - 11-23-2019, 03:29 AM
  Pinebook Pro on Debian 12 Power Issue u974615 1 346 03-13-2024, 10:46 AM
Last Post: u974615
  Increasing the maximum power draw dsimic 15 19,727 11-21-2022, 03:36 AM
Last Post: bircoph
  Alternative Power supply options gallomimia 13 17,996 11-13-2022, 06:10 PM
Last Post: pineymousepad
  PBP booting but stops at flashing power led jonasd 13 5,553 09-26-2022, 12:17 AM
Last Post: jonasd
  Blinking red light for charger, no power-on bifo 11 13,905 11-30-2021, 01:37 PM
  power on PBP if your keyboard is dead? stozi 0 1,345 11-29-2021, 01:55 PM
Last Post: stozi
  Motherboard malfunction - a possible warning about power supplies mjc 8 7,147 07-28-2021, 01:04 PM
Last Post: mjc
Question UK Power Supply User 11436 11 17,550 02-09-2021, 12:30 PM
Last Post: dieselnutjob
  Pinebook Pro Dock Power Requirements calinb 9 12,246 12-16-2020, 09:24 AM
Last Post: dsimic
  Auto-wake behavior when external power is connected diodelass 7 10,008 12-05-2020, 01:19 AM
Last Post: dsimic
