Power measurements
(11-21-2019, 10:22 AM)Der Geist der Maschine Wrote: Wouldn't rk-bat attribute "charge" be more appropriate?
That attribute (charge) is not present in /sys/class/power_supply/rk-bat/ on the factory installed Debian desktop on my unit. Even so, I would have to read the source code to understand the intent of an attribute named "charge" if it were present.
voltage_now seemed self-explanatory, and that attribute changes over time so it was a likely candidate for monitoring. If the battery does discharge while attached to DC power supply then it is reasonable to expect to see the voltage drop on voltage_now. This was not observed under test conditions I previously mentioned.
Power measurements - by jpakkane - 11-07-2019, 03:52 PM
RE: Power measurements - by VoxUnius - 11-10-2019, 10:42 PM
RE: Power measurements - by aaditya - 11-13-2019, 11:12 AM
RE: Power measurements - by VoxUnius - 11-13-2019, 08:43 PM
RE: Power measurements - by VoxUnius - 11-11-2019, 02:46 AM
RE: Power measurements - by hmuller - 11-11-2019, 05:08 AM
RE: Power measurements - by Axevy - 11-11-2019, 08:21 AM
RE: Power measurements - by danielt - 11-12-2019, 03:40 AM
RE: Power measurements - by MrTester - 11-13-2019, 09:09 PM
RE: Power measurements - by VoxUnius - 11-13-2019, 09:55 PM
RE: Power measurements - by aaditya - 11-21-2019, 12:13 AM
RE: Power measurements - by VoxUnius - 11-21-2019, 01:55 AM
RE: Power measurements - by pfeerick - 11-21-2019, 05:11 AM
RE: Power measurements - by hmuller - 11-21-2019, 05:58 AM
RE: Power measurements - by VoxUnius - 11-21-2019, 06:43 AM
RE: Power measurements - by hmuller - 11-21-2019, 02:16 PM
RE: Power measurements - by pfeerick - 11-21-2019, 09:42 PM
RE: Power measurements - by pfeerick - 11-22-2019, 03:31 AM
RE: Power measurements - by VoxUnius - 11-22-2019, 05:06 AM
RE: Power measurements - by VoxUnius - 11-21-2019, 11:45 PM
RE: Power measurements - by hmuller - 11-22-2019, 06:18 AM
RE: Power measurements - by pfeerick - 11-23-2019, 03:29 AM
  Pinebook Pro on Debian 12 Power Issue u974615 1 388 03-13-2024, 10:46 AM
Last Post: u974615
  Increasing the maximum power draw dsimic 15 19,897 11-21-2022, 03:36 AM
Last Post: bircoph
  Alternative Power supply options gallomimia 13 18,209 11-13-2022, 06:10 PM
Last Post: pineymousepad
  PBP booting but stops at flashing power led jonasd 13 5,694 09-26-2022, 12:17 AM
Last Post: jonasd
  Blinking red light for charger, no power-on bifo 11 14,145 11-30-2021, 01:37 PM
  power on PBP if your keyboard is dead? stozi 0 1,369 11-29-2021, 01:55 PM
Last Post: stozi
  Motherboard malfunction - a possible warning about power supplies mjc 8 7,271 07-28-2021, 01:04 PM
Last Post: mjc
Question UK Power Supply User 11436 11 17,742 02-09-2021, 12:30 PM
Last Post: dieselnutjob
  Pinebook Pro Dock Power Requirements calinb 9 12,378 12-16-2020, 09:24 AM
Last Post: dsimic
  Auto-wake behavior when external power is connected diodelass 7 10,104 12-05-2020, 01:19 AM
Last Post: dsimic
