Power measurements
(11-21-2019, 12:13 AM)aaditya Wrote:
(11-13-2019, 09:55 PM)VoxUnius Wrote:
(11-13-2019, 09:09 PM)MrTester Wrote: What exactly do we need tracked?
I am happy to throw the PBP on a DAQ at work with AC recording abilities, or open up and probe other values over a long term test.
Please let me know, I am happy to help collect data.
Well, it's been proven that the PBP needs more than 3A at high load (in my case, it was compiling a kernel with -j6). The question is whether a more powerful DC adapter would work with it. Is there any limitation in the charging circuitry? Can it take more than 3A?
As I said, I should be able to answer this question next Monday.
Any update mate? Does the 5V 4A barrel? adapter work?..
If the laptop is taking 3.5A on full load with -j6, I think it might be better to test it with -j2 to limit the current to 3A.
I haven't had time to test it properly. The only thing I noticed was that it still discharged the battery with -j6.
The combination that worked for me with the 3A adapter was limiting cores 5-6 to 1800MHz and putting the rest of them to powersave. That way it didn't drain the battery. And using -j2, yes.
Power measurements - by jpakkane - 11-07-2019, 03:52 PM
RE: Power measurements - by VoxUnius - 11-10-2019, 10:42 PM
RE: Power measurements - by aaditya - 11-13-2019, 11:12 AM
RE: Power measurements - by VoxUnius - 11-13-2019, 08:43 PM
RE: Power measurements - by VoxUnius - 11-11-2019, 02:46 AM
RE: Power measurements - by hmuller - 11-11-2019, 05:08 AM
RE: Power measurements - by Axevy - 11-11-2019, 08:21 AM
RE: Power measurements - by danielt - 11-12-2019, 03:40 AM
RE: Power measurements - by MrTester - 11-13-2019, 09:09 PM
RE: Power measurements - by VoxUnius - 11-13-2019, 09:55 PM
RE: Power measurements - by aaditya - 11-21-2019, 12:13 AM
RE: Power measurements - by VoxUnius - 11-21-2019, 01:55 AM
RE: Power measurements - by pfeerick - 11-21-2019, 05:11 AM
RE: Power measurements - by hmuller - 11-21-2019, 05:58 AM
RE: Power measurements - by VoxUnius - 11-21-2019, 06:43 AM
RE: Power measurements - by hmuller - 11-21-2019, 02:16 PM
RE: Power measurements - by pfeerick - 11-21-2019, 09:42 PM
RE: Power measurements - by pfeerick - 11-22-2019, 03:31 AM
RE: Power measurements - by VoxUnius - 11-22-2019, 05:06 AM
RE: Power measurements - by VoxUnius - 11-21-2019, 11:45 PM
RE: Power measurements - by hmuller - 11-22-2019, 06:18 AM
RE: Power measurements - by pfeerick - 11-23-2019, 03:29 AM
  Pinebook Pro on Debian 12 Power Issue u974615 1 376 03-13-2024, 10:46 AM
Last Post: u974615
  Increasing the maximum power draw dsimic 15 19,816 11-21-2022, 03:36 AM
Last Post: bircoph
  Alternative Power supply options gallomimia 13 18,114 11-13-2022, 06:10 PM
Last Post: pineymousepad
  PBP booting but stops at flashing power led jonasd 13 5,635 09-26-2022, 12:17 AM
Last Post: jonasd
  Blinking red light for charger, no power-on bifo 11 14,006 11-30-2021, 01:37 PM
  power on PBP if your keyboard is dead? stozi 0 1,350 11-29-2021, 01:55 PM
Last Post: stozi
  Motherboard malfunction - a possible warning about power supplies mjc 8 7,217 07-28-2021, 01:04 PM
Last Post: mjc
Question UK Power Supply User 11436 11 17,666 02-09-2021, 12:30 PM
Last Post: dieselnutjob
  Pinebook Pro Dock Power Requirements calinb 9 12,327 12-16-2020, 09:24 AM
Last Post: dsimic
  Auto-wake behavior when external power is connected diodelass 7 10,068 12-05-2020, 01:19 AM
Last Post: dsimic
