Default OS update log
#99
(12-02-2019, 12:52 PM)tuxor Wrote:
(11-30-2019, 11:55 AM)Luke Wrote:
(11-30-2019, 10:02 AM)tuxor Wrote:
(11-30-2019, 08:46 AM)sjk Wrote: Hi Just received my PineBookPro yesterday, and initial impressions are good. Updated using the supplied script to 1.5 without any issues.
My first hiccup is that suspend does not seem to be working. Hitting the power button and clicking suspend, cause it to sleep for a second, and then immediately wake up. Also closing the lid, does not seem to do anything, as I can still see the screen lit between the halves of the  clamshell.
Thanks,
Scott.
I am experiencing this too and fiddled around with it a bit but I could only get suspend to work once per boot. I don't have the logs handy right now, but there were some problems with systemd-suspend trying to put the eMMC back so sleep because they get a wakeup call from somewhere.
This seems to be an issue with newest update. I was trying to debug it, but it only happens occasionally for me. Try to reboot and suspend - it will likely suspend just fine.
If someone could catch a dmesg or better yet UART, then this would be very useful.
I attached my full dmesg with one suspend working and the second one not. When the suspend is not working I get the error marked below:
[  152.419256] PM: Preparing system for sleep (freeze)
[  152.422854] Freezing user space processes ... (elapsed 0.005 seconds) done.
[  152.428746] Freezing remaining freezable tasks ... (elapsed 0.001 seconds) done.
[  152.430454] PM: Suspending system (freeze)
[  152.430462] Suspending console(s) (use no_console_suspend to debug)
[  152.430683] [BT_RFKILL]: Enter rfkill_rk_pm_prepare
[  152.430685] [BT_RFKILL]: Disable UART_RTS
[  152.430731] [BT_RFKILL]: enable irq for bt wakeup host
[  152.432881] bcmsdh_sdmmc_suspend Enter func->num=2
[  152.432886] dhdsdio_suspend Enter
[  152.482286] bcmsdh_sdmmc_suspend bcmsdh_suspend err=-16
[  152.482311] dpm_run_callback(): pm_generic_suspend+0x0/0x4c returns -16
>>>>> [  152.482323] PM: Device mmc2:0001:2 failed to suspend: error -16
>>>>> [  152.482331] PM: Some devices failed to suspend, or early wake event detected
>>>>> [  152.581766] PM: resume of devices complete after 99.410 msecs
[  152.588643] [BT_RFKILL]: Enter rfkill_rk_pm_complete
[  152.588648] [BT_RFKILL]: ** disable irq
[  152.588658] [BT_RFKILL]: Enable UART_RTS
[  152.589250] PM: Finishing wakeup.
[  152.589258] Restarting tasks ... done.
After a reboot suspend works as expected again (only once though until next reboot).
Don't have access to UART tools right now, otherwise I'd be glad to do some more testing.
Can you please let us know if the latest release resolves the suspend/resume issue that you're seeing? v1.6 was pushed yesterday
Default OS update log - by Luke - 08-10-2019, 06:04 PM
RE: Default OS update log - by aleksei - 08-10-2019, 10:49 PM
RE: Default OS update log - by Luke - 08-12-2019, 10:25 AM
RE: Default OS update log - by zaius - 08-12-2019, 01:42 PM
RE: Default OS update log - by Luke - 08-12-2019, 04:43 PM
RE: Default OS update log - by zaius - 08-12-2019, 06:25 PM
RE: Default OS update log - by Luke - 08-24-2019, 01:21 AM
RE: Default OS update log - by sjk - 08-27-2019, 01:52 PM
RE: Default OS update log - by Luke - 08-27-2019, 02:25 PM
RE: Default OS update log - by binarian - 08-27-2019, 02:31 PM
RE: Default OS update log - by Luke - 08-27-2019, 02:39 PM
RE: Default OS update log - by Luke - 08-27-2019, 03:21 PM
RE: Default OS update log - by Luke - 08-30-2019, 02:21 AM
RE: Default OS update log - by Luke - 08-30-2019, 01:38 PM
RE: Default OS update log - by jvglynnjr - 01-16-2020, 04:03 PM
RE: Default OS update log - by Luke - 08-30-2019, 03:14 PM
RE: Default OS update log - by tllim - 08-31-2019, 08:56 AM
RE: Default OS update log - by zaius - 08-31-2019, 09:08 AM
RE: Default OS update log - by Thra11 - 09-05-2019, 06:05 AM
RE: Default OS update log - by User 6582 - 09-09-2019, 07:17 AM
RE: Default OS update log - by Thra11 - 09-11-2019, 05:46 PM
RE: Default OS update log - by User 6582 - 10-04-2019, 05:21 PM
RE: Default OS update log - by binarian - 09-10-2019, 09:04 AM
RE: Default OS update log - by binarian - 09-10-2019, 10:33 AM
RE: Default OS update log - by ayufan - 08-31-2019, 02:52 PM
RE: Default OS update log - by ac8dg - 09-08-2019, 02:41 PM
RE: Default OS update log - by tllim - 09-09-2019, 04:06 AM
RE: Default OS update log - by Luke - 10-04-2019, 03:20 PM
RE: Default OS update log - by neilman - 10-04-2019, 03:54 PM
RE: Default OS update log - by Luke - 10-04-2019, 04:22 PM
RE: Default OS update log - by bcnaz - 10-15-2019, 12:41 AM
RE: Default OS update log - by Luke - 10-15-2019, 03:47 PM
RE: Default OS update log - by bcnaz - 10-16-2019, 10:18 PM
RE: Default OS update log - by evilbunny - 10-16-2019, 10:45 PM
RE: Default OS update log - by richfm - 11-01-2019, 03:34 PM
RE: Default OS update log - by Watercourse - 11-01-2019, 03:43 PM
RE: Default OS update log - by embhorn - 11-03-2019, 09:42 AM
RE: Default OS update log - by User 6582 - 11-03-2019, 07:30 PM
RE: Default OS update log - by evilbunny - 11-03-2019, 07:32 PM
RE: Default OS update log - by User 6582 - 11-03-2019, 07:41 PM
RE: Default OS update log - by evilbunny - 11-03-2019, 07:42 PM
RE: Default OS update log - by User 6582 - 11-03-2019, 07:48 PM
RE: Default OS update log - by User 6582 - 11-03-2019, 09:20 PM
RE: Default OS update log - by evilbunny - 11-03-2019, 09:29 PM
RE: Default OS update log - by User 6582 - 11-04-2019, 06:37 AM
RE: Default OS update log - by zaius - 11-04-2019, 07:28 AM
RE: Default OS update log - by amp - 11-05-2019, 01:39 AM
RE: Default OS update log - by zaius - 11-05-2019, 12:05 PM
RE: Default OS update log - by amp - 11-06-2019, 02:36 PM
RE: Default OS update log - by amp - 11-04-2019, 01:42 AM
RE: Default OS update log - by Watercourse - 11-03-2019, 11:03 AM
RE: Default OS update log - by fpex73 - 11-03-2019, 11:54 AM
RE: Default OS update log - by Luke - 11-04-2019, 02:31 PM
RE: Default OS update log - by ak_hepcat - 11-04-2019, 05:15 PM
RE: Default OS update log - by Blackr0se - 11-05-2019, 06:32 AM
RE: Default OS update log - by Watercourse - 11-05-2019, 09:06 AM
RE: Default OS update log - by User 11436 - 11-09-2019, 08:54 AM
RE: Default OS update log - by bcnaz - 11-09-2019, 11:25 AM
RE: Default OS update log - by bcnaz - 11-18-2019, 11:38 PM
RE: Default OS update log - by Luke - 11-21-2019, 10:33 AM
RE: Default OS update log - by bcnaz - 11-21-2019, 12:31 PM
RE: Default OS update log - by Luke - 11-21-2019, 01:23 PM
RE: Default OS update log - by tophneal - 11-21-2019, 10:43 AM
RE: Default OS update log - by Luke - 11-21-2019, 01:25 PM
RE: Default OS update log - by Luke - 11-22-2019, 03:46 AM
RE: Default OS update log - by Luke - 11-23-2019, 03:10 PM
RE: Default OS update log - by neilman - 11-23-2019, 04:02 PM
RE: Default OS update log - by GLSRacer - 11-24-2019, 10:57 AM
RE: Default OS update log - by jiyong - 11-24-2019, 01:26 PM
RE: Default OS update log - by ryannshit - 11-24-2019, 05:55 PM
RE: Default OS update log - by Watercourse - 11-24-2019, 07:12 PM
RE: Default OS update log - by pfeerick - 11-25-2019, 03:37 AM
RE: Default OS update log - by GLSRacer - 11-24-2019, 07:16 PM
RE: Default OS update log - by Luke - 11-25-2019, 07:20 AM
RE: Default OS update log - by ryannshit - 11-25-2019, 11:55 AM
RE: Default OS (updated to 1.5) won's suspend - by Mrfixit2001 - 12-03-2019, 01:52 PM
RE: Default OS update log - by PabloR - 12-01-2019, 04:48 AM
RE: Default OS update log - by Jeffersoniantoo - 12-01-2019, 07:27 AM
RE: Default OS update log - by PabloR - 12-01-2019, 03:14 PM
RE: Default OS update log - by Jeffersoniantoo - 12-01-2019, 03:28 PM
RE: Default OS update log - by sjk - 12-04-2019, 08:17 AM
RE: Default OS update log - by Mrfixit2001 - 12-05-2019, 11:39 AM
RE: Default OS update log - by sjk - 12-05-2019, 03:29 PM
RE: Default OS update log - by tuxor - 12-08-2019, 05:24 AM
RE: Default OS update log - by Luke - 12-09-2019, 06:48 PM
RE: Default OS update log - by MiiCode2 - 12-09-2019, 09:58 PM
RE: Default OS update log - by sjk - 12-10-2019, 08:54 AM
RE: Default OS update log - by bbraun - 12-09-2019, 11:14 PM
RE: Default OS update log - by Luke - 12-10-2019, 03:06 PM
RE: Default OS update log - by sjk - 12-10-2019, 04:00 PM
RE: Default OS update log - by bigCamel - 12-10-2019, 11:49 PM
RE: Default OS update log - by sjk - 01-10-2020, 06:43 PM
RE: Default OS update log - by sjk - 01-16-2020, 07:54 PM
RE: Default OS update log - by Luke - 12-23-2019, 06:08 AM
RE: Default OS update log - by brent.thierens - 12-23-2019, 09:11 AM
RE: Default OS update log - by Luke - 12-23-2019, 09:32 AM
RE: Default OS update log - by e-minguez - 12-23-2019, 09:43 AM
RE: Default OS update log - by Luke - 12-24-2019, 11:46 AM
RE: Default OS update log - by tuxor - 12-24-2019, 11:09 AM
RE: Default OS update log - by sjk - 12-24-2019, 11:20 AM
RE: Default OS update log - by e-minguez - 12-25-2019, 12:57 AM
RE: Default OS update log - by brent.thierens - 12-28-2019, 04:30 AM
RE: Default OS update log - by e-minguez - 12-31-2019, 04:54 AM
Kernel sources - by kalpazanius - 01-05-2020, 07:25 AM
RE: Default OS update log - by bcnaz - 01-17-2020, 07:33 AM
RE: Default OS update log - by Luke - 01-17-2020, 07:39 AM
RE: Default OS update log - by Luke - 01-17-2020, 08:06 AM
RE: Default OS update log - by Luke - 01-17-2020, 09:25 AM
RE: Default OS update log - by as400 - 01-17-2020, 08:36 AM
RE: Default OS update log - by tophneal - 01-17-2020, 08:49 AM
RE: Default OS update log - by as400 - 01-17-2020, 08:51 AM
RE: Default OS update log - by as400 - 01-17-2020, 08:58 AM
RE: Default OS update log - by neilman - 01-17-2020, 10:22 AM
RE: Default OS update log - by Thanos - 01-17-2020, 12:04 PM
RE: Default OS update log - by tso4ev - 01-18-2020, 06:56 AM
RE: Default OS update log - by Luke - 01-18-2020, 07:11 PM
RE: Default OS update log - by bcnaz - 01-18-2020, 03:10 PM
RE: Default OS update log - by zaius - 01-18-2020, 03:29 PM
RE: Default OS update log - by Luke - 01-19-2020, 06:03 AM
RE: Default OS update log - by bcnaz - 01-18-2020, 03:37 PM
RE: Default OS update log - by tso4ev - 01-19-2020, 03:48 AM
RE: Default OS update log - by Envision - 01-20-2020, 12:14 PM
RE: Default OS update log - by Arwen - 01-20-2020, 01:20 PM
RE: Default OS update log - by Envision - 01-20-2020, 02:21 PM
RE: Default OS update log - by rnorfor - 01-24-2020, 06:19 AM
RE: Default OS update log - by wrzomar - 01-27-2020, 01:51 PM
RE: Default OS update log - by sjk - 01-30-2020, 02:07 PM
RE: Default OS update log - by agurenko - 01-31-2020, 03:32 AM
RE: Default OS update log - by SageFox - 02-05-2020, 05:44 AM
RE: Default OS update log - by LutzFechner - 02-05-2020, 09:07 AM
RE: Default OS update log - by vfr400racer - 02-07-2020, 02:27 PM
RE: Default OS update log - by Luke - 02-07-2020, 03:24 PM
RE: Default OS update log - by ac8dg - 02-07-2020, 04:26 PM
RE: Default OS update log - by amp - 02-08-2020, 02:12 AM
RE: Default OS update log - by xmixahlx - 02-07-2020, 05:39 PM
RE: Default OS update log - by rleasle - 02-08-2020, 12:10 PM
RE: Default OS update log - by amp - 02-09-2020, 01:47 AM
RE: Default OS update log - by wdt - 02-08-2020, 01:45 PM
RE: Default OS update log - by vfr400racer - 02-10-2020, 10:50 AM
RE: Default OS update log - by Arwen - 02-10-2020, 11:14 AM
RE: Default OS update log - by vfr400racer - 02-10-2020, 12:38 PM
RE: Default OS update log - by amp - 02-10-2020, 01:00 PM
RE: Default OS update log - by vfr400racer - 02-10-2020, 01:24 PM
RE: Default OS update log - by sirspate - 02-13-2020, 06:12 PM
RE: Default OS update log - by GLSRacer - 02-13-2020, 08:37 PM
RE: Default OS update log - by tuxor - 03-10-2020, 03:07 PM
RE: Default OS update log - by wdt - 03-11-2020, 10:44 PM
RE: Default OS update log - by Firedevil79 - 03-16-2020, 10:46 PM
RE: Default OS update log - by xmixahlx - 03-17-2020, 01:26 PM
RE: Default OS update log - by Luke - 03-17-2020, 04:29 PM
MATE for upcoming Distros? - by fritzf - 03-21-2020, 10:27 AM
RE: Default OS update log - by bcnaz - 03-21-2020, 06:47 PM
RE: Default OS update log - by xmixahlx - 03-22-2020, 10:33 AM
RE: Default OS update log - by fritzf - 03-22-2020, 10:48 AM
RE: Default OS update log - by hikaricore - 05-06-2020, 03:03 PM
RE: Default OS update log - by Dendrocalamus64 - 05-06-2020, 08:23 PM
RE: Default OS update log - by hikaricore - 05-06-2020, 09:48 PM
RE: Default OS update log - by tso4ev - 05-26-2020, 04:48 AM
RE: Default OS update log - by Luke - 05-26-2020, 06:25 AM
RE: Default OS update log - by tso4ev - 05-26-2020, 07:29 AM
RE: Default OS update log - by bchenlee609 - 06-06-2020, 02:16 PM
RE: Default OS update log - by User 6582 - 05-26-2020, 06:52 AM
RE: Default OS update log - by amp - 05-26-2020, 10:02 AM
RE: Default OS update log - by sinistermrcream - 06-01-2020, 01:44 PM
RE: Default OS update log - by xmixahlx - 06-06-2020, 03:17 PM
RE: Default OS update log - by bcnaz - 06-09-2020, 12:34 PM
RE: Default OS update log - by User 6582 - 06-09-2020, 02:54 PM
RE: Default OS update log - by sirspate - 06-11-2020, 08:03 PM
RE: Default OS update log - by xmixahlx - 06-11-2020, 11:25 PM
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 2,304 12-15-2023, 02:11 PM
  After update, multiple problems, pinebook pro. jd50i 1 1,068 09-16-2023, 09:41 AM
Last Post: jd50i
  Metis package can't update Mangustis 1 1,087 02-22-2023, 03:23 PM
Last Post: robocone
  Keyboard/Touchpad update SH61F83 IC zaphod80013 4 3,365 09-14-2022, 03:56 AM
Last Post: Carl
Big Grin EASY SOLUTION for Manjaro "Missing Keys" Update and Install Failure Zoroaster-Z 0 1,440 08-14-2022, 09:01 PM
Last Post: Zoroaster-Z
  Ring around screen following update tylerjohnson3208 2 2,129 05-10-2022, 01:52 AM
Last Post: diyagabriel
  Wont charge when powered off, and update question pineymousepad 7 6,059 12-11-2021, 09:50 PM
Last Post: pineymousepad
  Issues with External Display After Recent Update reundo 0 1,400 11-18-2021, 06:37 PM
Last Post: reundo
Bug Wrong FN keys after keyboard FW update j4n3z 2 2,622 10-19-2021, 01:57 AM
Last Post: j4n3z
  Trackpad firmware update Luke 263 363,110 07-28-2021, 12:52 PM
Last Post: Luke
