RPi.GPIO python module for Pine A64/A64+
#40
(08-09-2016, 02:30 PM)MarkHaysHarris777 Wrote: You will need to provide an external pull-up resistor 4.7k to 3v3...
...that will give you '1' unless you ground the pin (on the pin side of the 4.7k resistor.
Or, you can define the input as having a pull-up and then the pull-up will be internal.
PS  you can experiment with 'strong' or 'weak' pull-up resistors,  anything from 1k to 10k,   the higher the number, the weaker the pull-up.
PSS    I too will experiment with pin(3) GPIO02  as input... on debian...  will get back to you soon
http://forum.pine64.org/showthread.php?t...8#pid17268
(08-03-2016, 08:29 PM)MarkHaysHarris777 Wrote: hi Wolfenstein, when I code for a pull-up on an input pin ( I'm going to put a switch on it that pulls to ground ) then I leave it with the internal pull-up ( why use an additional component if not needed ).
Now you are confusing me.
RE: RPi.GPIO python module for Pine A64/A64+ - by Wolfenstein - 08-09-2016, 03:30 PM
  fm transmitter with gpio weasel18 2 4,862 09-10-2019, 04:28 AM
Last Post: desai_amogh
  How to use dts or other setup to declare gpio pin Interrupt (e.g. a button)? dkebler 1 3,622 06-12-2019, 10:37 AM
Last Post: dkebler
Lightbulb Sample GPIO codes highlighting RPi.GPIO-PineA64 and the PI bus MarkHaysHarris777 6 11,206 06-07-2019, 12:37 AM
Star GPIO, SPI and I2C C++ Lib databit 7 11,296 02-04-2019, 05:45 AM
Last Post: Jeff R
Information Howto: Controlling Pine64 GPIO via the filesystem (sysfs) on linux pfeerick 4 11,927 01-24-2019, 03:36 AM
Last Post: Fifth
  GPIO and SPI SamR1 20 31,822 03-15-2018, 10:32 AM
Last Post: jomoengineer
Question GPIO shockr 7 14,872 03-11-2018, 01:52 AM
  Read GPIO problem shworker 14 21,301 08-17-2017, 01:21 PM
Last Post: martinayotte
  Cross-wired Uart Ports between two Pine Boards via Cat5 Cable MarkHaysHarris777 10 16,098 11-20-2016, 04:17 AM
Last Post: pfeerick
  GPIO fiq capability joseph 3 6,150 11-10-2016, 06:07 PM
Last Post: joseph
